IDT-572 Middle Tn. Home again.................
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: IDT-572 Middle Tn. Home again.................
TravisRice wrote:Hey Blake. Cool deal on the iron head test.
Travis
I figured there would be several people that would enjoy that test. Glad you liked it.
You need to drop down and vist us sometime.
I was VERY impressed with that 40 year old Iron technology
D. Sea- Posts: 2208
I also think the loving rubbing from Mr. Snake helped a wee bit
D. Sea- Posts: 2208
Thanks Blake
Hey all, have not been on here for a while but maybe I can get back now. I appreciate all you do for us Blake. Keep talking and I'll keep listening.
BTW, any progress on that block deal?
Kerry
Kerry
knrclark- BBF CONTRIBUTOR
Coon and I have a good plan, just have trouble getting time to get together and get it done. I hope to get on it soon. I will let you know when we get some info.
O and thanks.
O and thanks.
10-4 Blake
No problem Blake. I can't start a build right this minute anyway. But...when you get the block deal going I will probably start. Just let me know when you are ready.
Kerry
Kerry
Believe me that wall looked close to me Dan.I wanna run it in the 1/8 some more before I let 'em hang on the 1/4'
BTW,I did pedal.....some.Kinda reminded me of driving on Ice for the first time.
---RED
56Tbird wrote:Blake if you keep letting red drive your car at BG down track ,your gonna get to see how good the primer's stuck to the metal and how well the cage is constructed!! That place is no place to take chances on a cool TNT night. I've seen a few crashes there over the years!! Red ,it's always better to pedal and make another pass![]()
61coon- Posts: 644
I guess I should add , I am from middle Tn. run a 86 mustang notch with a flat top 557. It started life as a TFS Street headed engine. running A best of 5.70 flat.
Then Charlie Evans and I in a joint venture ported a set of TFS Streets for Trick Flow as a proto type project. High port type deal, with still a smaller than cj port cross section. I ran them at the bash. ran 5.67.
I have bought a set of P-51 Kasse heads and pistons to run ,but in the mean while I have ported a set of Cast SCJ's to run until the new heads are ready. Right out of the box no tuning it went a 5.88 with the cast heads .
Just more info . Should have posted it in the first post.
D. Sea wrote:I was VERY impressed with that 40 year old Iron technology
I thought Blake was a little older than 40????
Boo Boo
stangr8cr- BBF CONTRIBUTOR
stangr8cr wrote:D. Sea wrote:I was VERY impressed with that 40 year old Iron technology
I thought Blake was a little older than 40????![]()
Boo Boo
Careful, some snakes DO BITE
D. Sea- Posts: 2208
Boo Boo
I am the same age as my gums and a little older than my teeth............
Page 2 of 2 •
1, 2
Page 2 of 2
