Flow Tool ?
Page 2 of 2 Previous  1, 2
Re: Flow Tool ?
Post  bruno on Sun 1 Aug - 12:38
no ...do not turn any fuel on "pump" ..... you are just going thru the motions to ck to make sure the noids are working
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Re: Flow Tool ?
Post  1Bad91 on Sun 1 Aug - 14:13
Yep....heard nothing. Is there a way to take them apart and check or just buy new ones and call it a day??
1Bad91
Re: Flow Tool ?
Post  bruno on Sun 1 Aug - 14:17
are you getting 12volts and a good ground at the noids ? when you hit the micro switch is it passing 12 volts thru it to turn on the noids? are you using any relays for the nitrous ?
if everything cks out good and you need some noids give Steve Johnson a call , he is still running his special ..i believe
JET BOAT BOB
Re: Flow Tool ?
Post  1Bad91 on Sun 1 Aug - 14:21
bruno wrote:are you getting 12volts and a good ground at the noids ? when you hit the micro switch is it passing 12 volts thru it to turn on the noids? are you using any relays for the nitrous ?
Getting 12 volts......and using a relay. I'm gonna dbl check everything again to make sure but the noids are about 8 yrs old
1Bad91
Re: Flow Tool ?
Post  1Bad91 on Sun 1 Aug - 14:22
I was so pissed....i been waiting to spray this thing and was stuck like a duck at the track...lol
1Bad91
