Torque slippage question
Page 3 of 3 Previous  1, 2, 3
Re: Torque slippage question
Post  richter69 on July 31st 2010, 8:44 pm
maverick wrote:Hey, Rick.....I just took my first peek at this thread. Are you sure of 4.30 ratio you're putting into the calculator? Just wondering, as I recall that chunk you got at the Bash was a 4.33. Dunno how much difference it makes, but did you ever do an actual tooth count? FWIW
this is true, my "4.33" is actually a 4.28............not sure how much that matters. Either way at that mph with the given gear and tire size the trap rpm should be a lot lower than 7400
Post  bbf-falcon on August 7th 2010, 10:25 am
When I bought it from Rich Talley at the Bash I counted it,I'm pretty sure it was a 4.33. Like Jon said,4.29 thru 4.30 it should'nt change that much.
Post  Larry Williams on August 7th 2010, 11:11 am
mine calculates to - 3.808 am I doing something wrong or is the converter too tight. it flashes to 4500
rpm 7200 tire 28 rear gears 4.57 mph 135.54
Larry Williams
Post  richter69 on August 7th 2010, 11:42 am
You can get away with the converter slip being lower and using a steeper gear.......if the car will 60' good with this combo it will move the car down the track better.
Post  Larry Williams on August 7th 2010, 12:34 pm
it was a 1.40 60 foot it wasn't a good launch the tires lift and settle right back down. Haven't done any shock of strut adjustments yet. will be renting the track one day this week if there is time before the big race this weekend just to play with settings.
I just changed from 4:10 to 4.57 its only a scat nodular crank so I didn't want to turn it too high. which gear do you recommend?
I do have a fresh 'glide with a 1:84 low gear sitting in my computer room waiting on the big bullet. should it help a bit?
Larry Williams
