Crank snout length ??
wowens
Does anyone have a photo of the long snout crank end with balancer and no accessories bolted up. Need measurements also from back of balancer to timing cover.
Have an opportunity to buy a long snout engine but want to make sure I can get it in the hole
wowens- Posts : 41
Re: Crank snout length ??
for what it's worth all are long snouts except for the Boss 429 Engines....
the Coug- Posts : 3055
the Coug wrote:for what it's worth all are long snouts except for the Boss 429 Engines....
Mine is a SCJ, Bryant crank with short snout
wowens- Posts : 41
yes you can order a short snout...
the Coug wrote:yes you can order a short snout...
He's not asking what he can oreder, he's asking what the legnth difference is to see it it will fit in his car.......must have a good deal on a regular snout crank
You can have the regular snout cut down to boss Length if needed.
ok
Boss or short snout is 3.670
Regular is 5.050
or that what mine measure on 3 different cranks....
Regular is 5.050
the Coug wrote:ok
Regular is 5.050
There ya go buddy!!! Direct hit !!!
the Coug wrote:ok
Regular is 5.050
Thanks Randy
That's what I need. I have been offered a sweet deal on a complete 598 engine that is new, but has the long snout and I don't have a long snout to measure for comparison. I run a external oil pump on a front motor plate and am trying to decide if I can make it all work since my current set up is the short snout crank before I buy this thing.
wowens- Posts : 41
you can always pull the crank and have it modified if the deal is too good to pass up.
dfree383 wrote:you can always pull the crank and have it modified .....
Correct. Adney is doing one for me now. Regular snout Scat 4340 with several options. Short Boss snout, knife edged and reduced diameter counterweights.
i have the long snout with pump mounted on motor plate, but.... when i ordered my pump , i had the mount plates set back in the middle of the pump to make it all work. you might could just change the mount plate location on your pump...
Randy[/quote]
Thanks Randy
That's what I need. I have been offered a sweet deal on a complete 598 engine that is new, but has the long snout and I don't have a long snout to measure for comparison. I run a external oil pump on a front motor plate and am trying to decide if I can make it all work since my current set up is the short snout crank before I buy this thing.[/quote]
Randy[/quote]
Thanks Randy
RGL- Posts : 27
[quote="wowens"][quote="the Coug"]ok
Regular is 5.050
where is this measured from? timing gear face to end of snout, or journal to end?
how long are the OEM spacers used on a long snout 429/460?
jim
Regular is 5.050
jim
TALONMAN69- Posts : 7
I measured from the front snout where the timing gear presses on to the end of the snout, without the timing gear....Lem may know the actual length of each spacer....
» spacer length behind balancer on crank snout ?
» Going from standard snout to boss snout crank
» BBF crank w/ chevy snout
» Boss crank snout.
» Shorten Eagle crank snout
» Boss crank snout.
