im confused ..cooling system question
Page 4 of 4 Previous  1, 2, 3, 4
Re: im confused ..cooling system question
Post  billandlori on August 13th 2010, 8:56 pm
You can get the pH test strips for checking coolant, it should be very close to a pH of 7 (neutral).
A very small amount of anti-freeze will still give the water a green tint. Having iron and aluminum together is like a small battery if the coolant is even a bit acidic (lower pH).
Bill
