Any certain valve cover fit the P51 better than others?
Page 2 of 3 • Share •
Page 2 of 3 •
1, 2, 3
Re: Any certain valve cover fit the P51 better than others?
c.evans wrote:57custom,
Keep in mind, he (John) asked about clearance with stud girdles. Are you running stud girdles?
Charlie
Yup I have Jomar stud girdles on my engine. If I knew how to post pics on this forum I would have posted a picture of the engine with the valve covers on.
57custom- Posts: 12
57custom wrote:c.evans wrote:57custom,
Charlie
Yup I have Jomar stud girdles on my engine. If I knew how to post pics on this forum I would have posted a picture of the engine with the valve covers on.![]()
Forgot to mention I had to cut out the baffles right below the oil filler and EGR holes on the stock covers.
57custom- Posts: 12
[/quote]
I would think that a set like I have would not be an issue.
[/quote]
Hey Rob!, What are you doing with my covers..
Btw, who makes theese? I bought mine used, like everything else.....
Regards.
Al
[/quote]Hey Rob!, What are you doing with my covers..
Regards.
Al
72mav- Posts: 849
Not sure on the manufacturer, I purchased these from Bret Powell at PFC Engines.
I've sure got no complaints on them.
schmitty- Moderator
Hate to keep beating a dead horse but is anybody using a set of the Moroso sheetmetals on some P51s?
jbozzelle- Posts: 2009
The girdle won't fit under pressed Moroso covers on P-51's, 100%. Colin
hienergy557- Posts: 54
just get you some of them Ford Racing deals and grind on um a bit................
richter69- Posts: 7464
bbf-falcon wrote:Mike Barker(Goin Postal) has these spacers on his engine.They are cheaper than a new set of covers and have a nice touch .imo.![]()
Does anyone know where I can get a set of these spacers?
Biggi
BB429- Posts: 1
I think Price Motorsports has those for sale?
dfree383- Posts: 5980
I have the Trick Flow sheetmetal valve covers with the felpro double gasket with thin metal inbetween.Also Jomar stud girdle,with no issues.Call Jet Boat Bob he did mine.Great looking covers.They should be on Trick Flow website.Michael
PROSTREET66- Posts: 244
These would fit. They are Moroso valve covers.
BigBlockFalcon- Posts: 179
richter69 wrote:just get you some of them Ford Racing deals and grind on um a bit................![]()
I have 3 sets of the ford covers and they all require a different amount of grinding . Some will have to be welded on the out side to work.
KY JELLY- Posts: 1096
Thanks Randy. I take it the grinding is done up near the top? I don't have the covers or the heads handy to look at. Is it because the cover tapers towards the top?
The grinding has to be done at the bottom area . The bolt bosses in the valve cover cause most of the clearance problem along with the changed valve angle of the p-51. Just be sure the valves are closed when checking.
I would say any valve cover that has thick bosses will have to be checked especially the sheet metal type with tubes welded in them. I personally would recommend the ford covers because you can weld the valley (tube) up and grind plenty of clearance and use a short Allen bolt or what ever your choice of fastener is. If you have to remove the lower part of a tube on a sheetmetal cover its going to be weak.
Thanks Randy. I appreciate it.
Page 2 of 3 •
1, 2, 3
Page 2 of 3
