1971 Ranchero GT - New Ad
Selling my Ranchero because I have a new project in mind. Some forum members have seen the car in person.
The restoration was completed in 2006 at a cost of $50K+ CDN and it has won many shows including class at the Calgary World of Wheels twice, class at the International Mustang Meets, and many others.
Car ran a best of 11.51 @ 117.6mph at Mega Ford Weekend in Mission B.C. in 2011.
Car is clean top to bottom and has a painted and detailed underside. The Kaase P51 headed 472 was built in July 2010 ( http://www.torinocobra.com/forum/viewtopic.php?f=21&t=15769 ) , the full manual reverse pattern shift C6 was freshened in Aug 2014 at the Merkl Race Shop. Comes with binder photo history of build, all dealer paperwork, and trophies.
I installed an NOS speedometer during the build that now reads just over 2200 miles. That is slightly high due to the 4:11's.
The Ranchero always draws crowds as there is nothing out there like it!
Price: $25,000 USd. I will deliver to the border at Sweetgrass Montana or Portal Saskatchewan
Ranch71460- Posts : 284
Re: 1971 Ranchero GT - New Ad
I want bad...
738drvr- Posts : 600
Looks like an electric vacuum pump setup. How well did that setup work for you?
GLWS
TJ
GLWS
TJ
Tommyj466- Posts : 322
Tommyj466 wrote:Looks like an electric vacuum pump setup. How well did that setup work for you?
GLWS
TJ
X2
very nice
res0rli9- BBF CONTRIBUTOR
I never got a chance to unhook it on the chassis dyno to make a comparison.
No oil leaks though!
738drvr wrote:I want bad...
The border crossing at Portal Saskatchewan is about 1/2 way between my place and yours...let's get er done!
Trade you:
http://www.460ford.com/forum/41-auction-block/165083-sell-trade-blown-alcohol-mustang.html
It's on carbs now.
It's on carbs now.
Some underside shots from when I built it:
The H pipe is 3 1/2" diameter through the Hooker Aerochamber mufflers. After the mufflers the tailpipes are reduced to 3" diameter. The entire system is ceramic coated and flanged for quick access to the driveshaft and transmission,
Here are some pics showing the 3"x2"x1/8" HSS subframe connectors and my 1/2" stainless steel supply and return fuel lines:
» value of 1971 429 SCJ
» 1971 Ranchero GT
» 1971 Ford LTD ?
» Compression for 1971 429
» 1971 72 73 MUSTANG
» 1971 Ranchero GT
» 1971 Ford LTD ?
