Innovators West Dampers
Page 4 of 5 • Share •
Page 4 of 5 •
1, 2, 3, 4, 5
Re: Innovators West Dampers
Yes.....it'd need to go back to I.W.
Lem Evans- Posts: 4073
Is anything special needed for the crank trigger setup? Do they offer a crank trigger setup/bracket to match their face or does everyone just use a MSD setup? For the boss snout with crank trigger face plate if it matters. Thank You KS
KEVIN S- Posts: 36
KEVIN S wrote:Is anything special needed for the crank trigger setup? Do they offer a crank trigger setup/bracket to match their face or does everyone just use a MSD setup? For the boss snout with crank trigger face plate if it matters. Thank You KS
The MSD bracket can be used.........we have had some brackets made for those that do not already have the MSD stuff.
Good stuff.......
Lem just a few questions
1) what's needed to work on short or long snouts cranks? (I have both)
2) Is there any up charge in price for the crank trigger unit?
3) do you sell the brackets and the sensor and is there enough hardware for both long and short snout cranks
Ace
Ace
powerstrokeace- Posts: 646
#209 and shorten the spacer to 2.300"...LONG standard unit.
#210 needs no spacer...plug and play....Boss lenght.
The trigger face option is $89
Race ready.....
Hi Lem. Does the trigger face have the magnets in it or do u have to run a magnetic pickup?Lem Evans wrote:#209 and shorten the spacer to 2.300"...LONG standard unit.
Chris
stanggt- Posts: 359
Page 4 of 5 •
1, 2, 3, 4, 5
Page 4 of 5
