AMOUNT OF LIFT ON SET OF DOVE-Cs STOCK
came across a good set of dove-C that have been never been touched with just changing springs to match the cam whats the most lift i can run on these heads, someone i was talking to said at like .525 lift they start to eat up the valve seals if the guides arent changed? IS THIS TRUE
2L8ULOST- Posts : 13
Re: AMOUNT OF LIFT ON SET OF DOVE-Cs STOCK
yes if the guides are not cut down.
res0rli9- BBF CONTRIBUTOR
I believe you can run a .540 lift if you don't use valve seals, .525 sound right right with valve seals from all the stuff I read on the dove-c heads when I was working on mine.
I've got a 720 lift roller in my mustang with DOVE-C heads.But the valves are not stock . I've got a set that came on a engine that look to have stock valves and it had a mid 500 lift cam.
56Tbird- BBF CONTRIBUTOR
With my original untouched dove heads, the retainer just touched the valve seal at .535 lift. I was using Comp Cams stainless steel rockers.
nickbay- Posts : 61
» how much lift can i use on a dove head with out
» how much valve lift on stock springs?
» Dove heads on stock 460
» Stock dove valves
» WTD; Need a set of stock main brg bolts, Dove, 2 bolt block
» Stock dove valves
