Block fill???
Block fill???
Post  95lightiningguy on November 15th 2010, 3:14 am
Hey guys, gotta problem I need some help with. The truck my son came home with, that he talked his mom into buying, I believe has a crack in one of the cylinders. I have already done a lot of work on it and called myself looking it over good but just found this while putting it back together after a hone for a ring and bearing job. My question is can I fill the block to just above the crack and it be okay? I know another block would be ideal but I really dont want to spend any more money than I have to right now. Dont plan on driving it much, just a backup for me until he turns 16 and can get his license. When he does turn 16 we will rethink it but just for now need a real cheap fix to get it back together so the city will leave me alone. Is this okay to do? Thanks for any input you have.
Jason
95lightiningguy
Re: Block fill???
Post  lghting94 on November 15th 2010, 12:03 pm
Hard block or block fill will not keep it from leaking I tried this once before and still ended up paying to have it fixed right.
You might try some J.B Weld on it.
lghting94
Re: Block fill???
Post  342g on November 15th 2010, 1:24 pm
Sleeve it.
342g
Re: Block fill???
Post  res0rli9 on November 15th 2010, 1:26 pm
342g wrote:Sleeve it.
X2
Re: Block fill???
Post  lghting94 on November 15th 2010, 1:32 pm
Oops didnt read correctly thought you meant on the outside of the block, definatly have it sleeved
lghting94
Re: Block fill???
Post  95lightiningguy on November 15th 2010, 1:52 pm
This block really isnt worth sleeving I dont believe. Been bored 60 already and can get another block for less than a sleeve. Thanks guys, didnt think it was a good idea but figured I'd ask the experts. Sad
95lightiningguy
