? about nitrous usage on motot
If you have a 1000 horse power motor N/A that is built for nitrous also how do you determine how much nitrous spray and determine how many stages you need?
Dre Day- Posts : 14
Re: ? about nitrous usage on motot
depends on what you are trying to accomplish. If you are running Pro Mod you are going to want several kits, If you are running a small tire car maybe just one kit. If you are asking how much you can spray on a 1000hp motor you just keep adding jets until it does not pick up or you kill it
studly- Posts : 512
the class you are wanting to run i would do 2-3 kits 600-800hp worth of the juice should net you were you want to be with et and the weight ........ I would get with Steve from Induction-Solutions and tell him about your engine build and im sure he will get you in the right direction ... i believe your engine builder and nitrous guys should communicate on such an elaborate build
Thanks bruno for the info did you get yourpm I sent you?
Dre Day- Posts : 14
