Super Duty trucks -> can the 6.0 & 6.4 be made reliable?
Post  BigBlockRanger on November 30th 2010, 9:57 pm
Been looking at used SD trucks and was wondering what "fixes" need to be in place for one of them to be considered "ok". Or is there no such thing? lol
Re: Super Duty trucks -> can the 6.0 & 6.4 be made reliable?
Post  bb429power on November 30th 2010, 10:02 pm
The 6.0, well there is the whole head bolt problem and you replace them with ARP bolts then you should be good with THAT problem.
I was told that the evac setup or something like that has dexcool that runs in it. Well its aluminum, dexcool and aluminum equals bad corrosion so you would basically end up pumping coolant right in to your engine. Forgive me if I made a mistake, but something like that happened to a kid here with their dads truck.
bb429power
View user profile http://michiganmotorheads.forumjonction.com/
Post  richter69 on November 30th 2010, 10:13 pm
You seem to know as much about 6.0/6.4 as you do electric golf carts............... Very Happy
One could "go through" a 6.0 and fix a bunch of the issues............start with a clean slate....approx 7-8k if it aint got serious problems.
The 6.4 deal get rid of the pos DPF, keep an eye on the coolant level (it will leak sooner or later) I'd even go as far as putting a level indicator of some sort on it.........coolant gets low.....egr cooler leaks....eng hydrolocks....bend rod........lots of $$$$$$ to fix.
Post  bb429power on November 30th 2010, 10:15 pm
So its the 6.4 that has the coolant problem?
bb429power
Post  richter69 on November 30th 2010, 10:19 pm
both...........even if the 6.0 locks it aint no big deal, 6.4.................about the 2 dozen or so that have done it at the shop.....2 didnt need shortblocks afterwards. And the 6.4..............yeah that cabs gonna be off sooner or later.
6.0/6.4 use the gold coolant, not the dexcool. 6.7 uses the "specialty orange"..........ie "dexcool"
Post  jbozzelle on November 30th 2010, 11:11 pm
Don't know nothing about the 6.0 but here's my take on the 6.4
My 2008 F350 has had the cab off at least 3 times. I'd have to pull an OASIS report to see for sure. It's had a HPFP, HPFP plug/harness, intercooler, radiator, turbo assembly and a DPF all changed under warranty. The truck has 101,000 on it now. I bought it last June with 49K on it. I drive the crap out of it on a daily basis. Overall it's a good truck. I plan to ditch the DPF and cat here soon so it will run better. Engine internal wise I haven't had any issues. It seems that the problems come from the emissions stuff on them. EGR, DPF, cat, etc...
Hey Fabio, Can I run the Rotella ELC "red" coolant in this 6.4? That stuff seems to be better than the Motorcraft Gold.
Any way you know of to completely bypass the EGR system? I know I can buy the plates to block off the exhaust gasses, but is there any way to disconnect the coolant hoses too or completely remove the EGR coolers so as to not worry about them rotting and leaking coolant into the engine? Also, someone told me the EGR is used on these trucks to relieve boost during high boost conditions and that removing it can cause the heads to lift? Any of this sound true?
Now, I put 100K on a 7.3 in just over 3 years. I bought it with 228K on it and bought my 6.4 when it rolled 330K. All that thing has ever had was a transmission, injectors and some various sensors, filters, gaskets, etc... But the truck is just worn out - suspension, body, interior... I still use it to run to the shipyards and boat docks and to haul trash and other dirty work, but it is nowhere as nice as my 2008...
Gotta take the good with the bad I guess...
Post  bbf-falcon on December 1st 2010, 1:01 am
[quote="richter69"]You seem to know as much about 6.0/6.4 as you do electric golf carts............... Very Happy
Shouldn't talk to your kid brother like that.I think he's your lil brother from another mother lol! ]
Post  56Tbird on December 1st 2010, 1:57 am
X2 on that Rick Twisted Evil king
56Tbird
Post  bruno on December 1st 2010, 7:39 am
from what ive heard ....... there is a local guy that buys up these 6.0 with 20-30k (for his fleet)on them the first thing he does is take the cab off , arp bolts , egr delete, new exhaust, air intake and sct programmer and he has these things runnin to 150-200k without a lick of problems and he uses the sct deal with a custom tranny program and mileage deal only ......i wish he would by my deal Laughing
there was a couple of other things he said he does mechanicaly but i cant remember
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  richter69 on December 1st 2010, 8:35 am
ha ha the cab off 6.0 tune up.............I dont like the studs, new stock bolts and new gaskets are just fine.
Post  dfree383 on December 1st 2010, 8:55 am
I put 122K on my 06 6.0....... Only issue was a dirty connector that affected starting..... simple fix with some dielectric grease.........
I did change oil religiously and ran synthetic........and the truck never sat around or did short BS trips.
Post  Doug Rahn on December 1st 2010, 5:43 pm
I think I would rather have Lem's stump pullin' 502 in a Super Duty than have a diesel Wink http://www.429-460.com/proven-builds-f4/502-f350-engine-t2925.htm
Post  61coon on December 1st 2010, 6:12 pm
Doug Rahn wrote:I think I would rather have Lem's stump pullin' 502 in a Super Duty than have a diesel Wink http://www.429-460.com/proven-builds-f4/502-f350-engine-t2925.htm
cheers cheers cheers cheers Me too Doug !!!!!
61coon
Post  duff429 on December 1st 2010, 9:37 pm
i like the looks of the harley edition 05 like my friend has but no way i would buy one.
iv been looking for awhile for a 99-03 with a 7.3. 2 door.
guy at work just picked up a 01 6 speed reg cab with 124,xxx for 10g Shocked lucky SOB if you ask me.
duff429
Post  BigBlockRanger on December 1st 2010, 10:24 pm
Looks like I may just keep looking at gas trucks seeing that I do not tow all that often. My neighbor has a F350 crewcab v10 that gets about the same gas mileage as my Durango. lmao I just want something I can haul the kids AND has a normal sized bed on it.
