8.50 or 7.50 Certified cage pictures in Fox
Page 1 of 1 • Share •
Anybody got any pictures or digrams of what a properly laid out roll cage for 8.50 or 7.50 certified should look like.
studly- Posts: 462
Re: 8.50 or 7.50 Certified cage pictures in Fox
a cheap investment would be an sfi book
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
Big differance between a 8.5 and 7.50 cage, 8.50 is your basic 10 point cage, 7.50 is SFI. You really need the SFI book to see all the bars under the car.
jones- Posts: 1413
Going with the SFI specs even if you never plan on going that fast can add to the future resale value of a car when/if you ever decide to sell it.
DILLIGASDAVE- Posts: 1176
I have a legal 10 point cage by this
http://www.nhraonline.com/contacts/tech_faq.html
just thinking about adding the funny car cage and 12 point bars to the front i guess i will order the book and see what has to be done
studly- Posts: 462
If your looking for an SFI book, & your car is a "back-half" car or a "mini-tub/stock suspension" car, you will probably need the 25.5 SFI spec book since it deals with cars that have stock/modified floor and firewall with OEM frame and/or uni-body construction.
DILLIGASDAVE wrote:If your looking for an SFI book, & your car is a "back-half" car or a "mini-tub/stock suspension" car, you will probably need the 25.5 SFI spec book since it deals with cars that have stock/modified floor and firewall with OEM frame and/or uni-body construction.
agreed. very easy to understand too.
whatbumper- Posts: 1762
car is stock suspension no mini tubs and untoched floorplans as of yet, I have weld in sub frame connectors, but was thinking of adding threw the floor subframs while interior is out and upgrading cage over the winter, car is getting to fast without trying to upgrade cage. I do have the normal upgrades, upper and lower controll arm reinforcement, anti roll bar and solid bushings with all upr bolt in suspension parts and qa1 double adjustable shocks bolt in. but the floorpan has never been cut just reinforced with plates above the upper control arm mounts and lower controll arm mounts in rear.
studly- Posts: 462
after you do the through floor subframes there really isn't much more to do with the floor with what you described you have. spend the $20something dollars for the SFI 25.5 book.
