428 fe help
Page 2 of 2 Previous  1, 2
thanks again for the valuble information
Post  dbran on Thu Dec 16, 2010 2:32 pm
I ordered a 3.70 ring and pinion from Strange with refresh kit. I will attempt to ID the cam and see how the car performs with the new gears.
Thanks again
Dave
dbran
forgot too add
Post  dbran on Thu Dec 16, 2010 2:34 pm
I was able to ID the intake it is a Blue Thunder as one of the forum members suggested, Thanks!!
dbran
Re: 428 fe help
Post  rmcomprandy on Thu Dec 16, 2010 5:59 pm
Which Edelbrock cylinder head was probably determined by the exhaust bolt pattern needed in the mustang.
There are things to be checked to give you a better idea of what you're dealing with. As Barry said, first thing is to check the cam timing and valve lift - it does sound as if it is retarded.
Be sure you have enough intake valve to piston clearance in order to advance the cam timing if necessary. I have seen engines put together with the cam installed "wherever it needs to be" for getting enough clearance; damn where it's timed at. That's not a good thing but, sometimes necessary just to "get it together now" and fix it later. Being the car was auctioned tells me someone may have been in a hurry along the line.
IF that is the case, you WILL need a smaller camshaft.
IF that is not the case you can advance the cam you have 6 or 8 degrees to gain some torque.
Last edited by rmcomprandy on Thu Dec 16, 2010 7:42 pm; edited 1 time in total (Reason for editing : Typo's)
Re: 428 fe help
Post  plovett on Thu Dec 16, 2010 6:51 pm
dbran wrote:I was able to ID the intake it is a Blue Thunder as one of the forum members suggested, Thanks!!
Sweet! Very Happy I'm glad to hear it. That's a very good intake. Now you can focus on the other stuff.
paulie
plovett
3.73 gears installed
Post  dbran on Fri Feb 18, 2011 10:39 am
Just finished installing the new 3.73 gears. WoW . the car seems just right. never drops out of the power band. nail it a 10-20mph and it rips the tires off. hits second spins for about 2-3 seconds and chrips third! of course this is with the gt 500 oem tire size ( f70-15) . need to try it with some good tires.also I readjusted the valve lash.question? if I play with the exhaust lash and loosen it a bit will it increase cylendr pressure and make the cam act loke it has a little less duration and lift or does it need to be done on both intake and exhaust.or is it not reccomended. also wht is a good cold or hot spec
dave
dbran
