8.8 questions
8.8 questions
Post  frank13 on December 17th 2010, 4:17 pm
Ok, So i wanna have 9 inch ends installed on my 8.8 to not have to use the cclip eliminators, local shop says they can do for 200 installed with parts.....sounds fair to me
So axle wise: Do i need to change the current axles, or do i get them modified.
Is the axle an off the shelf item
Do i need to change anything brake wise, can i use the brakes and e brake i already have on the car? (2002gt rear discs)
I am not narrowing the axle at all, but i have no clue (didnt think to ask the chasis shop, and didnt wanna bug him again)
frank13
View user profile http://www.frankskinkracing.com
Re: 8.8 questions
Post  dfree383 on December 17th 2010, 5:01 pm
You need to buy a set of proper length axels set-up for the 9" ford bearings, your existing 8.8 will not work.
Call Strange, Moser or another manufacture of your choice and get what you need.
Re: 8.8 questions
Post  frank13 on December 17th 2010, 5:08 pm
ok what about the brakes?
frank13
Re: 8.8 questions
Post  whitefield on December 17th 2010, 8:29 pm
strange makes a set up to run your existing axles.I will get the part number for you tomorrow from the set that I bought for my car. Here is a link
http://www.strangeengineering.net/catalog/pages/016.jpg
whitefield
Re: 8.8 questions
Post  frank13 on December 18th 2010, 11:36 am
whitefield wrote:strange makes a set up to run your existing axles.I will get the part number for you tomorrow from the set that I bought for my car. Here is a link
yeah, found strange and moser both make a set, but i cant figure out the right part numbers
any help will be appreciated!
frank13
Re: 8.8 questions
Post  frank13 on December 20th 2010, 6:24 pm
any luck finding that part number for me....
i am looking at part numbers
h1137 (ends) and b1706mc(brake braket)
but they think i need to change the axle also
frank13
Re: 8.8 questions
Post  dfree383 on December 21st 2010, 11:50 am
if you get the proper bolt pattern and flange depth you can reuse your stock brakes. Call Strange and talk with them.
Re: 8.8 questions
Post  whitefield on December 22nd 2010, 12:21 am
Sorry it took so long I had forgotten about it ! The part numbers that I have are: A 1092 and A 1090C . These are the c - clip eliminator for stock axles and the part no. for what they call a wedding ring or locking collar. good luck and I hope this helps.
whitefield
