Fabricated Aluminum Dual Tunnal Ram
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: Fabricated Aluminum Dual Tunnal Ram
nice............
richter69- Posts: 8199
^^^ What he said.......
That tunnel ram is a true work of art!!!....
Tennessee Bullitt- Posts: 525
DILLIGASDAVE wrote:procrap makes a low cost, paper thin "backfire-edition" sheetmeal tunnel ram for the 351-C......maybe they also make one for the 460 too?![]()
how is that damage the intakes fault? pop off valve would of helped. ive seen very high $$$ intakes bend,warp,etc when this happens. wasnt the fault of the intake.
BOSS 429- Posts: 1514
BOSS 429 wrote:how is that damage the intakes fault? pop off valve would of helped. ive seen very high $$$ intakes bend,warp,etc when this happens. wasnt the fault of the intake.
Procrap makes parts of these T-rams (like the plenum box, plenum top, & carb base) out of such thin sheet material that vacuum leaks & backfires are bound to happen. These are so paper thin in some areas that I wouldn't be surprised if a small sneeze (that doesn't open a pop-off), would still balloon the top/sides.
big name sheetmetal tunnel ram makers out there are smart enough to know a cheezy paper thin carb base/mount with damn Riv-nuts isn't going to seal anything very well......no wonder there was vacuum leaks/backfires.
A well made sheetmetal tunnel ram from a reputable manufacture is a little heavier than what people might expect them to be. They use a thicker/rigid top plate (vs the procrap siht) for a much better seal between the top & plenum base, and between the top & the carb(s).
DILLIGASDAVE- Posts: 1176
Looks like their welder is top notch.... makes me wanna go light myself on fire and jump off a cliff than to want something like that.
Soda can intakes...
Par for the course w/Pro-Crap BBF parts..
DFI429- Posts: 277
The world will "implode"!!!!!
crittersf1- Posts: 211
crittersf1 wrote: The world will "implode"!!!!!![]()
Its already doing it........
Page 2 of 2 •
1, 2
Page 2 of 2
