Opinions on BBF build- X275 Car
Page 3 of 3 • Share •
Page 3 of 3 •
1, 2, 3
Re: Opinions on BBF build- X275 Car
so why wouldnt a specific head program work for this class ....meaning a larger surface area port vs. more velocity , so you can fill it up the chambers with more nos , compare to your standard 1000hp bracket head ........ if you look at the dyno on my 562" /edel heads the torque is not a x275 buster ....... just a thought
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
its not the hp, its the torque.
richter69- Posts: 8199
I am not a head guru, but i thin nick is on the right track you really need to take in the consideration of flow vs velocity to get a good combo. these cars should run in the 470-490 range this year. do the math on the HP to run that fast, turbos 3300lbs, nos 2950, NA 2800lbs and all on a 275 radial. we have several of the cars that run in this class close to me. one has the sbf NOS fastest pass 4.97 another has the fastest MPH turbo car, also a SBF, there are so many options to go it is hard to nail down the perfect combination because therre is not enoph enoph on people running the BBF to have a killer set up. I will be watching for these combos this year while i finish my new motor.
studly- Posts: 462
richter69 wrote:its not the hp, its the torque.
thats the point of my statement ....
JET BOAT BOB
bruno- Moderator
Just getting started back up...been researching alot of combos and I think narrowed it down to A-460, big bore/short stroke. Will have definite plans and pics within the next several days.
fuel- Posts: 10
any updates on the x275 build ?
JET BOAT BOB
bruno- Moderator
r u allowed a C-head ? if so maybe thats the way to go -small cubes and turn that bitch to 8200-8400 with the spray
badcoupe- Posts: 63
badcoupe wrote:r u allowed a C-head ? if so maybe thats the way to go -small cubes and turn that bitch to 8200-8400 with the spray
no to the C-head on spray...only N/A...
138- Posts: 1584
so what direction did you go in?spill the beans man!
Larry T- Posts: 573
Page 3 of 3 •
1, 2, 3
Page 3 of 3
