8.8 Posi issues
Page 1 of 1 • Share •
8.8 Posi issues
The mav. has an 8.8 posi unit and its staying that way for right now. Sometimes when I'm in the burnout box (usually where it happens, very seldomly does it do this on the street) it will do a one wheel peel. Any idea what causes this? Could it be the fluid level or the fluid itself? What's an easy fix for this if there is one?
bb429power- Posts: 2741
Re: 8.8 Posi issues
have you rebuilt it ever, prob a combo of the oil and clutches,bb429power wrote:The mav. has an 8.8 posi unit and its staying that way for right now. Sometimes when I'm in the burnout box (usually where it happens, very seldomly does it do this on the street) it will do a one wheel peel. Any idea what causes this? Could it be the fluid level or the fluid itself? What's an easy fix for this if there is one?
frank13- Posts: 402
Re: 8.8 Posi issues
I haven't, but the previous owner said he put it in. It was fine but then it started acting up more recently, I haven't checked the fluid yet. In storage at grandparents house, but I do want to check it. Is there a special additive or rear end dope to put in it like a LSD style axle?
Re: 8.8 Posi issues
time for a rebuild. you can buy factory Ford additive at the dealership
whatbumper- Posts: 1762
Re: 8.8 Posi issues
Justin, the 8.8 takes the usual gear oil and a friction modifier, or a pre-mix of both. If it's not too old a fresh change may help.
DFI429- Posts: 277
Re: 8.8 Posi issues
If you are mostly drag racing the car you might want to have the rebuilder set it up real tight by shimming it. I added shims to my wife's Roush's 8.8 when I swapped in 4.10's. That's about the best you can do for a trac lok it this application.
4thHorseman- Posts: 233
Re: 8.8 Posi issues
Mainly it is on the street in the summer, I do take it to the track twice a year
But I want to go more often. Later down the road this thing is going to be TOTALLY reformed in to the baddest drag car around these parts
But until then, I don't think I'll rebuild the 3rd member just yet. Soon when I can get it back in my own garage or when its warmer at least, I want to check the fluid. Maybe pull it apart and completely refill it. Depending on the cost I could rebuild it while its apart, just curios what would cause this so I can plan another project.
Thanks guys, I will take in to consideration all of the things said above.
Re: 8.8 Posi issues
needs rebuilt, it is an 8.8, and not a factory 8''?
BOSS 429- Posts: 1514
Re: 8.8 Posi issues
BOSS 429 wrote:bb429power wrote:The mav. has an 8.8 posi unit and its staying that way for right now. Sometimes when I'm in the burnout box (usually where it happens, very seldomly does it do this on the street) it will do a one wheel peel. Any idea what causes this? Could it be the fluid level or the fluid itself? What's an easy fix for this if there is one?
8.8
