Twin Turbo Help
Twin Turbo Help
Post  oktw88 on February 17th 2011, 6:15 pm
Building a 466 big block with around 8.5:1 compression. Planning on running a pair of these turbos listed below. Now will they perform good on this setup? Also what type of horsepower can this make on low boost and pump gas?
Borg Warner S400w/75mm compressor wheel with Extended Tip Technology,1.10 A/R exhaust
Turbo Specs:Compressor Wheel Inducer/Exducer 75mm x 100mm with ETT
Turbine Wheel Inducer/Exducer 96mm x 87mm
Turbine Outlet 5 Inch V-Band
Turbine Inlet T6 Divided
Turbine A/R - 1.10
Also its going in a car thats mainly street driven so the boost will not be nothing too outrageous and run on pump gas(93 Octane).
Thanks for the input
oktw88
Re: Twin Turbo Help
Post  whatbumper on February 17th 2011, 10:28 pm
I would go with 76's or 80's. Probably 80's with a 1.0 or 1.08 A/R.
Re: Twin Turbo Help
Post  Northwest outlaw on February 18th 2011, 1:20 am
The right twin 76mm turbo can take you to 1500+ hp.....X2 on the 1.0 or 1.08 or even 1.32 with the big cid I would look at the bw s400 it is a 76mm turbo with a 1.32 and can be had for around $600.00 each new....just my .02 $
Northwest outlaw
Re: Twin Turbo Help
Post  EVE on February 18th 2011, 9:26 am
I now have a set of 88's with 1.32 housings for my 528ci. Haven't tried them out yet but they have been over 200mph on a Chevy so I should get 300mph out of them. Laughing
EVE
Re: Twin Turbo Help
Post  VETTKLR on February 19th 2011, 5:15 pm
Damn right! Laughing
VETTKLR
Re: Twin Turbo Help
Post  oktw88 on March 7th 2011, 8:38 am
Northwest outlaw wrote:The right twin 76mm turbo can take you to 1500+ hp.....X2 on the 1.0 or 1.08 or even 1.32 with the big cid I would look at the bw s400 it is a 76mm turbo with a 1.32 and can be had for around $600.00 each new....just my .02 $
I found these, would they be a good option?
Borg Warner S400w/75mm compressor wheel with Extended Tip Technology,1.32 A/R exhaust
Turbine A/R - 1.32
Horsepower Rating 500-1050
oktw88
Re: Twin Turbo Help
Post  whatbumper on March 7th 2011, 8:56 am
yep!! I am a big fan of the new BW technology.
Re: Twin Turbo Help
Post  Brian Brown on March 10th 2011, 9:35 am
oktw88 wrote:Building a 525 big block and planning to do a twin turbo setup. If I do twin 88's with a .96 A/R is that the right size turbos to run on a big block and allow it to breathe. Also its going in a car thats mainly street driven so the boost will not be nothing too outrageous.
I'm assuming those are GT4788's you are referring to. On a max effort setup, you might be giving up a few hundred horsepower, but those GT4788's will still make really good power. You really need a little larger A/R if your are looking for a max effort setup. You will run into some backpressure in the higher pressure ratios.
Brian Brown
Re: Twin Turbo Help
Post  Northwest outlaw on March 10th 2011, 10:06 pm
PM sent back.
Northwest outlaw
Re: Twin Turbo Help
Post  oktw88 on March 12th 2011, 8:15 am
On the setup I posted above will it be safe to run around 8-10lbs of boost on a factory D0VE-A block or should i go ahead and start looking into buying an aftermarket block. The car is mainly going to be street driven and run on pump gas. Also the RPM's will be kept at 6K or below.
oktw88
Re: Twin Turbo Help
Post  Northwest outlaw on March 12th 2011, 11:38 am
Just a quick run down in my eyes you will be fine. The key to make any thing live is the tune..read the plugs read the plug it is the window inside your motor.
Northwest outlaw
Re: Twin Turbo Help
Post  oktw88 on March 12th 2011, 12:58 pm
Thanks alot for the help.
oktw88
Re: Twin Turbo Help
Post  Northwest outlaw on March 12th 2011, 2:21 pm
No problem some time i dont get back to fast as we are testing and protyping new parts.
Northwest outlaw
Re: Twin Turbo Help
Post  '65 T-BOLT on March 13th 2011, 12:40 am
Northwest outlaw wrote:No problem some time i dont get back to fast as we are testing and protyping new parts.
How is the chassis coming along?
'65 T-BOLT
Re: Twin Turbo Help
Post  Northwest outlaw on March 13th 2011, 2:22 pm
We have put it on hold for now. We will pick it back up after we get our turbochargers, bov, wastegates on the market.
Northwest outlaw
