Two piece driveshaft u joint angles
Two piece driveshaft u joint angles Empty Two piece driveshaft u joint angles
Post  Greg_P February 11th 2011, 1:06 am
I put a 4" lift on my '95 F350. Now I have some U-joint vibes on initial acceleration.
I have a 7 degree angle on the center U-joint, and 0 degrees on the rear U-joint.
The lift blocks on the rear have a pretty severe up angle built into them. I think this is the problem. I have been playing with dropping the center support bearing but no luck getting rid of the vibes.
What kind of angles should I be shooting for, and how can I correct the rear end angle? I don't see how wedge type shims would work on a 1 ton truck.
Thanks,
Greg_P
Greg_P
Two piece driveshaft u joint angles Empty Re: Two piece driveshaft u joint angles
Post  DILLIGASDAVE February 11th 2011, 8:52 pm
Sorry Boss, I used to have a site saved on my old fried computer that had some good examples of truck U-joint operating angles. But now I can't find the site/remember the name of the site.
If I find it I will post it.
Post  Diggindeeper February 12th 2011, 12:40 am
did you take your driveshaft apart when installing the lift?
is the pinion nut tight?
Diggindeeper
Diggindeeper
Post  Greg_P February 28th 2011, 12:06 pm
Well I did some researching and found that guys sometimes lower the center support bearing to work on u joint vibration. Well, I lowered the center support bearing about an inch and it helped big time.
Greg
Greg_P
Greg_P
