529cu short block
Page 1 of 1 • Share •
529cu short block
D1te block (baked and shot blasted) 2-bolt main
Arp main studs
KB Forged flat top 4.42 pistons (.017 bellow deck, factory valve pierce points)
Total Seal file fit rings
4.3 Scat cast crankshaft
6.8 Scat Forged H-beam rods
King bearings
Durabond extra wide cam bearings
FRPP high pressure oil pump
FRPP Steel adjustable dbl roller timing chain
Canton sheet metal oil pan and pick-up tube (fits mustangs and pretty much anything else.)
FRPP hyd lifters
Trend pushrods
Custom ground Comp Cam (ground for heavy vehical applications)
FRPP head gasket
Scat flexplate
The rotating assembly was balanced by Crankshaft Specialties out of Detriot, MI.
Block machine work was handled by Lance Flake
Assembly was handled by myself
$2,200 you pick-up.
Philadelphia, MS
601-562-9371
Josh
Or trade for a side by side or nice atv
Arp main studs
King bearings
FRPP hyd lifters
Trend pushrods
FRPP head gasket
Scat flexplate
$2,200 you pick-up.
Philadelphia, MS
601-562-9371
Josh
jones- Posts: 1413
