stage stacking
Page 2 of 2 Previous  1, 2
Re: stage stacking
Post  Induction-Solutions on April 4th 2011, 9:59 am
quick 52 wrote:is it better to use hard line to from solenoid to plate or stainless braided hose. if hose do you no a good site to buy from
You can hard line or use SS/Teflon hoses. If you need any parts we can help you if you'd like. We can make your nitrous and fuel lines for your set up in about any lengths and sizes you'd need.. Please feel free to call Katie at the shop if you need any. 352-593-5900.. Thanks, SJ
Steve Johnson
Induction Solutions
4000 Crum Rd.
Brooksville, Fl. 34604
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
View user profile http://www.Induction-Solutions.com
Re: stage stacking
Post  quick 52 on April 7th 2011, 9:21 pm
well i started wiring the dual stage system today using 2 relay in the truck cab.. running 5 wire to the engine bay i most of hit my head 10 times crawling around in and under.. dont think ill ever get it done im wiring all the relay plugs no pigtails sodering and shrink tube every connection really takes the time.. hope this system works out for me cant wait till we can run up here in mi. it will be about may..
quick 52
Re: stage stacking
Post  quick 52 on April 8th 2011, 9:31 pm
the fpss i have heard that they can shut the nitrous system off and on during a run if used. so is best to use one or not i have been running without a couple years but with redoing the system this is the time to do or not. also the location u use when installing before reg. or after hope this pig is going to squeal
quick 52
