hook me up
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: hook me up
well to be honest i have been working on my nitrous setup. plus i also fab up a new fan shroud out alum. burred all the welds smooth and finish with 800 paper. i'll tell u that was a pita but after polishing it looks great. the weather here is just getting good in the high 60 but alot of rain. not quite ready to run yet need to finish up the new wiring hope this old truck is going to rock. will keep you inform on the setup and et
quick 52- Posts: 254
Re: hook me up
bb429power wrote:Have you found a good pressure yet? I'm trying some new ET streets and I haven't raced yet. They are at 35psi at the moment.
When I ran 28x12.50 et streets on the maverick I ran anywhere from 11.5-12.5psi. Of course it weighed less than 2700 with me sitting in it.
whatbumper- Posts: 1762
Re: hook me up
I have never ran the et streets i here they work very well on stick car where dr wont hook my friend runs them in his 347 stick car at 12psi. i have run 12 in the dr but it was no better than 14psi so been at 13 to 14 psi each track is differentwhatbumper wrote:bb429power wrote:Have you found a good pressure yet? I'm trying some new ET streets and I haven't raced yet. They are at 35psi at the moment.
When I ran 28x12.50 et streets on the maverick I ran anywhere from 11.5-12.5psi. Of course it weighed less than 2700 with me sitting in it.![]()
Re: hook me up
Car weight has a lot to do with it but I have seen a lot wider range in pressures in the drag radials that works for a particular combo. We plan on running 10.5-11.5 psi this year in our slicks but that is a whole different ball game.
We are going to run some 275 events this year and we have a good tune for those tires but I would rather put them on another set of wheels(that we don't have) because ours are 15x12. I would rather put them on a 15x10 preferably dbl beadlock.
Re: hook me up
quick 52 wrote:well to be honest i have been working on my nitrous setup. plus i also fab up a new fan shroud out alum. burred all the welds smooth and finish with 800 paper. i'll tell u that was a pita but after polishing it looks great. the weather here is just getting good in the high 60 but alot of rain. not quite ready to run yet need to finish up the new wiring hope this old truck is going to rock. will keep you inform on the setup and et
Cool, I will keep an eye on the topic. I'm going to be running at Milan tomorrow with the new tires. These are ET streets, 26" by 10.5 (I think that's the overall width) with an aspect ratio of 60. The weather is getting nicer (knock on wood), Gary at Milan does a good job prepping the track. I will lower the pressure some and see how she looks. I only have like 3 qualification rounds so I hope I can get it straightened out.
Not sure on the weight, 70 maverick with a 68 302 swapped in, some purple hornies for exhaust at the moment, 8.8 rear end, no back seat...as of now.
bb429power- Posts: 2741
Re: hook me up
bb429power wrote:quick 52 wrote:well to be honest i have been working on my nitrous setup. plus i also fab up a new fan shroud out alum. burred all the welds smooth and finish with 800 paper. i'll tell u that was a pita but after polishing it looks great. the weather here is just getting good in the high 60 but alot of rain. not quite ready to run yet need to finish up the new wiring hope this old truck is going to rock. will keep you inform on the setup and et
What is the part number of the tire you are running? You are confusing the hell out of me. Are you running ET streets or ET Street Radials? It should be 3752, 3752R, 3753, or 3753R
Re: hook me up
Looks like the new ones I got are these:
http://www.summitracing.com/parts/MTT-3752R/
But I do have the x275's on my other car.
Re: hook me up
bb429power wrote:Looks like the new ones I got are these:
that explains it. Summit always puts the old sizing crap on there instead of Mickey Thompsons size. The actual size is P235/60R15. The other number is the equivalent if they had to fit in the same space. 8.4" tread and 26.1"tall
You can fit the P275/60R15 easily on the Maverick. I had 28x10.5 slicks and 28x12.5 ET streets (same size) on mine so I would think a P295/55R15 would fit.
Re: hook me up
whatbumper wrote:bb429power wrote:Looks like the new ones I got are these:
We took it in to a tire shop we have gone to before to have them fitted, the reciept says they are 10.5's
Summit could have it messed up, we were only looking to go to 10.5's for right now, but later
Re: hook me up
the 295's are 10.5's. the 275's are 9.5's
Page 2 of 2 •
1, 2
Page 2 of 2
