Race alternator, 9" Pro Gears, more
Post  David Cole on April 17th 2011, 1:56 pm
Powermaster 100 amp race alt and bracket kit # 8-897. 1 Wire setup, almost new, no room for it on my current car. This alt and bracket + a crank pulley sells for $363 as a kit. Fits a bbc or you can use it in any car with a motorplate, just cut spacers to length and bolt to the plate. $185 (no crank pulley). Firm + any shipping.
View user profile http://my.att.net/p/s/community.dll?ep=16&groupid=66449&ck=
Re: Race alternator, 9" Pro Gears, more
Post  David Cole on April 17th 2011, 2:00 pm
Richmond Gear 9" Pro gears. 3.89 Large pinion. about 20 passes on them. Good shape. New these sell for $375. Take $175 + shipping or might trade up with some cash for a complete 9" center with 28 spline axle Trac lock setup and 3.25 or so gears.
Hurst V Matic shifter. Looks a little rough, but works. Includes cable and C-6 pan bracket. Will work with a C-4 if you buy a bracket. Will need to buy the shifter arm ($20) Sells new for $205 Take $50
Post  David Cole on April 17th 2011, 2:06 pm
Stock Powerglide case and tail. Bare. $50
Misc parts:
Mr Gasket Copper exhaust gaskets. Fit BBC or Blue Thunder BBF w chevy exh. New $32, sell $15
MRG composite ex gaskets, same fitment as above. New $22, sell $10
Permacool remote oil filter mount for Ford filter $10
powerglide yoke, new old stock oem. Uses U bolts instead of press in cups. Makes trans change easy and no mess. Just unbolt from the driveshaft and leave it in the trans. $20
Post  David Cole on April 17th 2011, 2:09 pm
All parts are plus shipping. I can deliver to the Bash for no charge.
Alternator and gears would require payment up front.
David Cole 256 390-7252
leave message if no answer (must turn phone off while at work)
Post  dr's wife racing on April 18th 2011, 10:13 am
David I'll take the PG yoke just hold on to it untill the bash.Thanks Ward
dr's wife racing
Post  David Cole on April 18th 2011, 8:14 pm
dr's wife racing wrote:David I'll take the PG yoke just hold on to it untill the bash.Thanks Ward
Ward, Done!
Sale pending on the alternator.
sale pending on the gears
Post  61coon on April 18th 2011, 10:02 pm
I'll take those copper gaskets if you don't mind waitin til the bash.---RED
61coon
Post  Maddmattmustangs on April 20th 2011, 7:01 pm
Does the shifter have reverse lockout?
Maddmattmustangs
Post  David Cole on April 20th 2011, 7:16 pm
Maddmattmustangs wrote:Does the shifter have reverse lockout?
Yes, to put it in reverse you use two fingers and lift the smaller two hole handle in front of the main shifter handle.
Post  bcr466 on April 21st 2011, 6:17 pm
David, if Ward changes his mind on the trans yoke I will take it. Dont think he will but--------?
bcr466
