466 Engine
466 Engine
For Sale: 466, D1 block, TRW 14.1-1 CR pistons, Truck rods with football bolts, AR429 heads by Charlie Evans Racing less that 20 runs since almost $1000.00 worth of work in 2010, harmonic balancer, Crane Gold roller rockers, flat tappet cam by Lem Evans.
What is not available with this engine; Intake, Carbs/Injection, oil pan, distributor, water pump, fuel pump cover plate, flex plate, and plug wires.
My car has run a best of 6.05 at 115 in cold air, this summer in the heat 3 weeks ago 6.29 at 109. In 2010 at the Big Block Ford Bash best of 6.15 at 114.
Asking $4600 for complete engine as described above, will separate heads for $1950 and short block for $2900. Can work with buyer on delivery arrangements. You may call me at 870 489-1250 if you have questions.
Kerry
Kerry
knrclark- BBF CONTRIBUTOR
Flow Numbers
Forgot to include these
Intake: 100=71, 200=144, 300=209, 400=274, 500=323, 600=344, 700=355, 750=358
Exhaust 100=62, 200=118, 300=162, 400=189, 500=212, 600=223, 700=230, 750=232.
Re: 466 Engine
Bump...Anybody interested?
Re: 466 Engine
Ran the car tonight in some good air, went 6.17 at 111. this engine could be yours.
Re: 466 Engine
Why you selling it Kerry?
342g- BBF CONTRIBUTOR
Re: 466 Engine
342g wrote:Why you selling it Kerry?
Trying to build a stroker, need the money to finish it.
Re: 466 Engine
Got ya, good luck.knrclark wrote:Trying to build a stroker, need the money to finish it.342g wrote:Why you selling it Kerry?
Re: 466 Engine
342g wrote:Got ya, good luck.knrclark wrote:Trying to build a stroker, need the money to finish it.342g wrote:Why you selling it Kerry?
Thanks Harold
» 514ci BLUE THUNDER HEADED ENGINE & bbf parts,and engine for sale
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» 653 CI Thor Headed big block Ford engine / ENGINE SOLD THANKS!!!!!
» Engine Masters 414" stroker 351W street/strip engine
