Greenbean - The 98GT
+7
Jamie V
manofmerc
2 wicked
11 posters
Page 4 of 4 Previous  1, 2, 3, 4
Greenbean - The 98GT - Page 4 Empty Re: Greenbean - The 98GT
Post  BigBlockRanger December 7th 2021, 10:45 am
I put a few bolts in the front accessory drive plate. It took a while to find bolts in the bolt box that were the right length and it was a little tricky getting the gasket to lay flat. Once the main bolts were in, I set the alternator on. Like the cam position sensor, I was concerned that the raised intake might present a problem, but it fit perfectly.
Greenbean - The 98GT - Page 4 20211217
The next task was to index the trigger wheel for the crank position sensor. With a magnetic sensor like this it's pretty easy. The wheel is free to spin so with the engine at TDC, you just line up the proper tooth (5th one from the missing tooth for an EEC-V) and the magnetic field holds it there while you mark it. Then you pop it off and weld the wheel to the hatchet spacer. Easy peasy.
I also worked on the front engine accessory drive, mounting the harmonic balancer, spacer, crank pulley, idler pulley and belt tensioner.
Greenbean - The 98GT - Page 4 20211216
Greenbean - The 98GT - Page 4 20211218
Mark Miller and 1EFF100 like this post
Post  BigBlockRanger December 9th 2021, 10:03 am
Converter is in and the trans is on! It went together really easy. Almost time to drop it in. Just need the header adapter plates my friend is making for me an it will be ready.
Greenbean - The 98GT - Page 4 20211219
Post  BigBlockRanger December 13th 2021, 5:22 pm
E4OD controller mounted and transmission dipstick shortened. The dipstick was for a truck so it would have stuck out of the hood by a good 8". Haha.
Greenbean - The 98GT - Page 4 20211224
Greenbean - The 98GT - Page 4 20211223
Post  Mark Miller December 14th 2021, 12:14 am
BigBlockRanger wrote:Converter is in and the trans is on! It went together really easy. Almost time to drop it in. Just need the header adapter plates my friend is making for me an it will be ready.
Is that the Oil Pan that came with the Truck Engine?
Post  BigBlockRanger December 15th 2021, 10:22 am
Yeah it is the stock F-250 pan. Same pan that is used for Fox swaps.
Post  Mark Miller December 16th 2021, 12:52 am
BigBlockRanger wrote:Yeah it is the stock F-250 pan.  Same pan that is used for Fox swaps.
That's the same oil pan that i have on my 466 in my Mustang although i just bought the Canton 429-460 Fox Body Swap oil Pan to put on in the future!!
BigBlockRanger likes this post
Post  BigBlockRanger December 30th 2021, 3:18 pm
While Judd was grinding rivets to remove the ball joints on his car, I started on wiring the Optishift transmission controller.
Somewhat surprisingly, I had a hard time finding the correct wiring diagram for a 1998 Mustang GT. I finally bought a 1 month subscription at www.alldata.com and found everything I needed and more. $20 well spent.
The sucky part of this wiring project is that the ecu is in the passenger kick panel. I had to remove the passenger seat so I could get my big, stupid body in there to access the wiring. So far I have power, ground and the TPS connections soldered in.
Next challenge is getting a speed sensor signal to the ECU and to the Optishift. This E4OD does not have a speed sensor output so we have to come up with a work-around solution. This is the same problem we had to overcome with the F250 project. On it, we took a front wheel ABS signal, ran it thru a Ford F-250 PSOM, then it went to the ECU and Autometer speedometer.
If I am thinking correctly, we should be able to feed the rear ABS signal to the Optishift, and then use it to output the proper 8000 pulse per mile signal to the ECU.
Post  BigBlockRanger January 3rd 2022, 12:53 am
When Plan B becomes Plan A. I was planning to use some adapter plates to bolt the standard 460 headers to the efi heads. I was not 100% convinced I liked the idea. Today, Is found some very thick washers the perfect diameter to fit in the header tube. I cut them, welded them in and ground down the welds. I will shape up the ports with the die grinder and surface them on the belt sander. Should be good to go with no additional width added to the engine.
Also, it is amazing how much easier it.is.to.weld wearing my reader glasses. Haha. Getting old sucks.
Greenbean - The 98GT - Page 4 Img_2033
Greenbean - The 98GT - Page 4 Img_2034
Post  BigBlockRanger January 3rd 2022, 12:55 am
I finished up the headers. I am really happy with how they turned out. I installed them and then we decided to try to drop the engine in the car.
We (Judd, Jonathan and me) struggled with it quite a bit. We pushed and pulled, jacked and pried, but could not get it to move back and drop over the engine mounts. Then I noticed that there was a tab on the side of the E4OD that was hitting the firewall. I was tired of messing with it so we quit for the day. Once I trim that tab off, it should slide back and drop over the mounts This AJE k-member has engine mounts that looks nice but are really hard to deal with.
I think it was a good call on not using a header adapter plate. I doubt the engine would have fit with the headers on. It is really tight going in.
Greenbean - The 98GT - Page 4 Img_2035
Greenbean - The 98GT - Page 4 Img_2036
Greenbean - The 98GT - Page 4 Img_2037
In retrospect, had I not modified the engine mounts to move the engine 3/4" farther to the rear, the engine would already be bolted in the car.... Oof. Haha.
Mark Miller, 1EFF100 and John Myrick like this post
Post  BigBlockRanger January 5th 2022, 12:14 am
And it's in! I sawed the offending tab off, which is waaaay easier said than done, and wiggled it back and over the mounts. Slipped a bolt in each side and let out a sigh of relief.
Greenbean - The 98GT - Page 4 20220110
Post  BigBlockRanger January 6th 2022, 11:47 am
Man, what a pain. I started working on the steering shaft and it quickly became evident that there was no way it was going to fit. Not even close. Like several inches off. I have had plenty of trouble in the past getting the steering shaft to fit thru these Hooker 6224's. It wasn't a huge problem with the old QA-1 kmember that offset the engine to the pass side (like stock). But when I went to a motor plate that centered the engine, it was a huge problem. It appears that this K-member centers the engine as well. I am sick of fighting them. I think I am going to cut the #7 header tube and reroute it to create a much larger space for the steering shaft. #7 has been bashed on a lot to make the shaft fit. The #5 tube may need to be massaged a little as well, we'll see. Luckily the header basically falls out of the car and luckily Judd has a 460 head I can bolt them to while cutting and welding.
Greenbean - The 98GT - Page 4 Image_35
Greenbean - The 98GT - Page 4 20220111
Post  BigBlockRanger January 7th 2022, 10:48 am
#7 tube chopped out of the way. Slipped header back in. #8 tube is going to need a big-ish dent to clear the frame rail because of the engine offset, (or lack thereof.) #5, #6 & #8 will all clear the steering shaft fairly nicely. I think #8 will fit better when I drop the back of the transmission down just a little. It is currently as high as it will physically go. Dropping it a little with also improve access to the electrical connector on the top of the E4OD's MLPS, which incidentally got crushed when we installed the engine and trans. Luckily I have a spare.
Post  BigBlockRanger January 11th 2022, 1:23 am
Worked on the adapter plate for the throttle body a little today. It was going great until I realized I drilled and tapped the TB flange holes 90°off. Nice. That would be great if I wanted a forward facing TB, but if I did that, absolutely nothing else would fit properly. Looks good though. Haha. 🙄
Greenbean - The 98GT - Page 4 Fb_img11
Greenbean - The 98GT - Page 4 Fb_img10
Greenbean - The 98GT - Page 4 Fb_img12
Post  BigBlockRanger January 12th 2022, 12:32 am
I figured out that if I rotated the throttle body elbow slightly, the diagonal bolts would line up with a couple of holes. So I marked two more holes, drilled and tapped them. The rotation is not really noticable.
Greenbean - The 98GT - Page 4 Img_2038
Post  BigBlockRanger January 12th 2022, 9:11 pm
I cut the big hole in the TB adapter plate today. It cut pretty easily with a coarse blade in a jigsaw. The trick is to use a little WD-40 and it cuts real easy and nice. Then I took the die grinder and cleaned it up. I am very happy with how it turned out even though the TB is rotated a skosh.
Overhead shot so show throttle cable routing.
Greenbean - The 98GT - Page 4 20220112
Post  bruno January 13th 2022, 9:37 am
Man this has been a great project to keep up with !! I cant wait for the intial startup !!
http://WWW.CKRME.COM
BigBlockRanger and Mark Miller like this post
