1969 Galaxie 500 - high school/college kid budget build
Page 4 of 4 • 1, 2, 3, 4
Re: 1969 Galaxie 500 - high school/college kid budget build
I was a little *meh* about his wheel choice at first, but now I think he nailed it.
BigBlockRanger- Posts : 1198
Mark Miller- Posts : 1882
BigBlockRanger likes this post
I still can't believe he only paid $1300 for it.
69F100 and Mark Miller like this post
Everything works! And I can still hear!
https://youtu.be/tekVUBaJPDc
I thought this thing had a huge header leak so I slipped the headers down and put header gaskets in it. This was probably the easiest car to put header gaskets on that I've ever experienced.
Great. I finish up and then fire it up and it still has a huge exhaust leak up by the number five cylinder. What is going on?? It sounds like it's right behind where I mounted the coil. So I popped the coil off and lo and behold the core plug for the thermactor port is rusted out!
Now of course Ford could not use a normal size plug like 5/8 or 3/4 or something like that they had to use an oddball size that basically nobody has. But I got lucky. I went to my local O'Reilly store and asked for a core plug and the guy pulled out a book and started looking up part numbers and found a part number that would probably work. Not in stock. Closest one was in Kentucky. Boo. He checked another part number that was slightly larger and amazingly enough, he had three in stock. I bought all three.
I took them back to the shop, cleaned out the hole, and pounded the new one right on in. Win. No more leak!
BigBlockRanger wrote:Easiest exhaust system ever. Haha.
I had one of those pop out driving down the road when i had the 466 in my LTDII and i was like WTH was that!!Sounds good with what looks like Flowmaster Mufflers!!
Parker likes this post
Parker- Posts : 1
Yesterday, he brought it up to the shop and he and his buddies from HS started installing the radiator. It was good to see them all hanging out in the shop together again.
Hood clearance is going to be interesting.
Judd and Josh finished it up yesterday and took it for a spin around the parking lot. Seems to run strong, but he didn't get too froggy because it is really low on transmission fluid.
He took it on a drive and he was very happy with how it ran. Water temp stayed low and consistent and he said he drive it kinda hard. I can attest to that because I could hear him.
I have not figured out how to embed Youtube shorts.....
https://www.youtube.com/shorts/eTtSUoYjHVk?si=a24C1X-xtE4p7UsC
BigBlockRanger wrote:Judd had an oil leak at the back of the motor. We thought it was the plastic oil pressure gauge line, so he put a copper line on yesterday. Nope. It's the manifold to china wall leaking. He is going to clean it up and and try to seal it up today.
Sounds good about what my 466 in my LTDII sounded like with a Lunati Bracket Master II 00097 230-230 Duration@.050 .554-.554 Lift and 9:5.1 Compression TRW 2404 Dished Pistons Dove-C heads i also had the Stealth Intake with a 850 Holley DP!!
Mark Miller wrote:BigBlockRanger wrote:Judd had an oil leak at the back of the motor. We thought it was the plastic oil pressure gauge line, so he put a copper line on yesterday. Nope. It's the manifold to china wall leaking. He is going to clean it up and and try to seal it up today.
I have that same Lunati, Old Part number and all. It will likely go into my 472PI and I use one of the bigger cams on the High Compression 466 with better heads.
Those wheels look like SS Craigers. Nice.
supervel45- Posts : 4452
supervel45 wrote:Mark Miller wrote:BigBlockRanger wrote:Judd had an oil leak at the back of the motor. We thought it was the plastic oil pressure gauge line, so he put a copper line on yesterday. Nope. It's the manifold to china wall leaking. He is going to clean it up and and try to seal it up today.
That cam worked pretty good IMO and yes those were Cragar SS Wheels the LTDII ran a best of a 13.26@101 mph with that cam not bad for a 4,420lb. car with driver back in 1996!!
BigBlockRanger wrote:Bad ass!
Thanks that car was probably the most fun car i've built so far even though it was the slowest it was always driven to the track and back home except for one race that was 90 minutes away!!The picture i posted wasn't from 2020 it was a picture of a picture probably 1995 or 1996!!
supervel45 wrote:Mark? What Gears Convertor and Heads/Portwork did you have? Sorry for the derail 83.
3.70 Gears,C-4 with a 10"TCI Street Fighter Converter,DOVE-C Heads can't remember if they were ported or not if they were they had very little work done to them and they Had SSI Valves Stock DOVE-C Size!!
» 352 FE 1962 Ford Donated High School Auto Shop Engine
» need help budget build 460
» low budget 460 build up
» Budget build questions
