Multi keyway crank timing gear
I'm in the process of putting together a MEL 430 engine and may need to correct the timing of the cam I'm getting ground, MEL parts aren't exactly easy to source and am worried I won't find a timing set with a multi keyway crank gear, does anyone know if a 429-460 crank gear can be substituted? I know the ID is the same as both the 429-460 and FE but don't know if the offset is the same so that the chain run will have proper alignment.
427John- Posts : 88
» Advance Cam or Not ?
» which timing gear?
» If it was easy, everyone would do it...
» Timing Chain Or Gear Drive
» Broken dowel pin in timing gear
