COMP Cams 34-229-4 - COMP Cams Magnum Hydraulic Cam/Lifters
The Comp cam and comp lifters are used. Actually 10 mud drag passes. They were broke in correctly and the liftes were numbered when pulled.
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,800-5,800
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 224 int./224 exh.
Advertised Intake Duration 270
Advertised Exhaust Duration 270
Advertised Duration 270 int./270 exh
http://www.summitracing.com/parts/CCA-34-229-4/
$150 shipped
Justin
$150 shipped
Justin
jcoxracing- Posts : 282
» Comp Xtreme 4X4 Hydraulic Cam and Lifters (NEW)
» Custom comp hydraulic roller cam and lifters
» COMP Cams 841-16 Endure-X, Sheet metal valve cover, Ultra Pro Magnum roller rockers
» comp cams lifters
» Comp Cams Roller Lifters
» comp cams lifters
