Problem fitting dry sump feed in dragster
I have a question for anyone here who has put a C and C Motorsports block with a dry sump system in a dragster. I have a new Miller dragster and I am installing a BBF that was built for a door car into it. The problem I am trying to solve is that the -12AN fitting for the dry sump feed to the block in the front by the timing cover on the drivers side is hitting the upper chassis tubing. Do I shim/raise the front of the engine so it fits? Or is there a special type of AN fitting or hose I can use? Has anyone else run into this deal?
rickb3653- Posts : 1
Curt- Posts : 2787
QtrWarrior likes this post
» Front sump vs rear sump
» Switching from dry sump to wet sump.....
» PG fitting ?
» xxxxxxxxxxxxxxxxxx
» Vent fitting on C6, best spot to tap?
» PG fitting ?
