2.1 Inch Diameter Rod Journal
Anybody running a 2.1 inch diameter rod journal? Have a new 4.5 billet crank (2.2 dia journal) with some chatter marks on the #8 journal. Trying to decide if i want to go .010 under or reground to 2.1 dia since I have not purchased rods yet...thoughts?
tompietwo- Posts : 43
Re: 2.1 Inch Diameter Rod Journal
tompietwo wrote:Anybody running a 2.1 inch diameter rod journal? Have a new 4.5 billet crank (2.2 dia journal) with some chatter marks on the #8 journal. Trying to decide if i want to go .010 under or reground to 2.1 dia since I have not purchased rods yet...thoughts?
It is done all the time especially when using aluminum rods. Getting a rod to match the journal WIDTH is the normal problem.
Oliver is the only ones I know that have Rods with 2.100 6.800 .990 Rods. When I bought my set 10 years ago they where $1500.00 a set of 8.
And then after regrinding the crank you have to have it nitrated again.
Dan
Dan
TRUKPULR wrote:Oliver is the only ones I know that have Rods with 2.100 6.800 .990 Rods. When I bought my set 10 years ago they where $1500.00 a set of 8.
Dan
Saenz, Crower and Carrillo also have them. There must be some other manufacturers out there if you can find them.
if .010 will fix it i sure would'nt go to 2.1.JMOtompietwo wrote:Anybody running a 2.1 inch diameter rod journal? Have a new 4.5 billet crank (2.2 dia journal) with some chatter marks on the #8 journal. Trying to decide if i want to go .010 under or reground to 2.1 dia since I have not purchased rods yet...thoughts?
I'd just repair it back to 2.200 no big deal. especialy if its only one journal.
» With an offset ground factory 460 crank, is there a significant strength difference between a 2.375" journal and a 2.2" journal?
» Ford Racing JC51 heads
» Cam journal in A460 blocks
» Main Bearing Journal?
» Tire diameter?
» Tire diameter?
