setting timing with vaccum advance
i am having a brain fart, what is the correct way to set timing while using vacuum advance...or it is better to not run the vacuum advance on a mild 429 using a dizzy that has a re-curve kit in it..what determines the amount of advance if using a vacuum advance?
johndickjr- Posts : 896
Re: setting timing with vaccum advance
pull the vac hose off the dizzy set it .but it depends on what cam if you need it or not I have ran cams that worked great with out the avanced hooked when hooked couldn't ever to get the preformance out of it as I could with unhooked.but have ran cams that would not preform with out it hooked.
69F100 wrote:pull the vac hose off the dizzy set it .but it depends on what cam if you need it or not I have ran cams that worked great with out the avanced hooked when hooked couldn't ever to get the preformance out of it as I could with unhooked.but have ran cams that would not preform with out it hooked.
and dont forget to plug the hose when you take it off.. a golf Tee works great
res0rli9- BBF CONTRIBUTOR
» inital timing setting
» Advance Cam or Not ?
» need some vaccum help
» Do I do a vaccum pump
» vaccum pump guys
» vaccum pump guys
