Start REtard Box ?
Start REtard Box ?
Had a friend bring a car over wanted me to check out why the time keeps getting off..He said everytime he would set the time' take it down the rd and floor it a few times' come back and it would be running different and have to reset the time...I took a tq wrench and turned the crank and watched the rotor button! Wasn't any more play than normal' have seen alot worse..I undone the start/retard box and just plugged the dist straight to the ign box...Drove it myself and it pulled hard and strong and never missed a lick...Any of you guys seen these retard boxes cause this problem? I fix 6 and 6AL msd's everyday...But havent been able to get any parts for the retard boxes yet....thanks
colormebad- Posts : 262
Re: Start REtard Box ?
If its a Ford check the roll pin in the distributor gear.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
I've had a Chevy that the timing kept creeping around on. We found that the dizzy wasn't tight enough to the block when the clamp was tight and the dizzy would turn as the RPMs went up. This thing would lose a few degrees every pass...
jbozzelle- Posts : 3705
Me
I had a similar problem when I was trying to fix my starter problem. I installed a retard box and had a lot of trouble with it being consistent. I can't say I was having to move the distributor every time but the timing jumped around a lot. In addition it seemed to work sometimes and not others. I had an MSD tech explain to me how it works and it all made sense. I'm not technically able to explain it to you now but in essence, the box works on averages and will not retard the exact same every time. Long story short, the timing was not my starting problem and I removed the retard box and all is well now. I believe the box would have been more consistent with down track retards instead of on start up.
knrclark- BBF CONTRIBUTOR
» Wtb timing start retard
» MSD start/retard
» WTB.. Start retard
» Start retard and cranking.
» MSD start/retard
