Mounting engine in chassis
Page 1 of 3 1, 2, 3  Next
Post  bcr466 on November 30th 2011, 9:21 pm
This will apply to engine as well as chassis so I didnt know which section to put in in. I have a front engine plate 1/4 aluminum, a .090 center plate and a crossmember in car for trans. mount. What I am considering is using the center plate, fabbing solid engine mounts from oe block mounting holes to chassis, or to front of heads, (Iron heads) and not using the front plate, giving more clearance for headers, cam changes or just room for maintenance.
Or, use front plate and center plate both. Either way I will use a rubber trans mount on the crossmember. The long 5/16 bolts as the only attachment to front of engine are my concern. I know lots have been mounted this way with no problems and some with problems, but I have the oppertunity now to do it different ways.
What have some of you used with success and what would you have changed on yours if you did it over and what are your opinions on this car? This is an aftermarket chassis car (Alston) race only, 532ci, PG (stock case) 4.30 gear with 17X33 tires. I will also have fore and aft bars on each side.
bcr466
Re: Mounting engine in chassis
Post  the Coug on November 30th 2011, 9:26 pm
Bob they say NEVER mount the engine and trans in all 3 spots something will break and most likely the trans for it is the softest metal front and trans or front and back of block leave trans hang. I like the front and trans...
Post  dfree383 on November 30th 2011, 9:27 pm
Do not attach motor plates to the heads, use the front of the timing cover.
Post  whatbumper on November 30th 2011, 9:33 pm
I would do aluminum front, with a mid plate and rubber trans. Proven to work.
Post  cool40 on November 30th 2011, 9:40 pm
i use the same setup you do but no trans crossmember.the front plate bolts have never been a problem on mine.
Post  69F100 on November 30th 2011, 9:51 pm
whatbumper wrote:I would do aluminum front, with a mid plate and rubber trans. Proven to work.
x2 my trans mount has no pressure what so ever on it mounted in a nuatral postion I use for keep the engine from wanting to move farward or backward
Post  cool40 on November 30th 2011, 10:02 pm
thats what'll break a glide.i never thought about it till i found my crossmember bent,i put limiters on it at the trans first and pulled the bolts outa the tailshaft.i put them back and also put them on the block at the factory mounting points.
Post  bcr466 on November 30th 2011, 10:32 pm
This is why I asked. Pros and cons of each. I knew if there were any problems this would be the place to find an intelligent answer from folks who have been there done that. BTW what I was calling fore and aft isolaters are also referred to as limiters.
bcr466
Post  richter69 on November 30th 2011, 10:37 pm
front and midplate here, no trans cross member or mount, my lateral limiters bolt where the tranny mount would have, and run back to the driveshaft loop................stock case glide here and taihousing.
Post  dfree383 on November 30th 2011, 10:52 pm
For whats its worth, my dragster has front and mid plates and uses limiters from the back of the shorty glide to the frame on both sides, No trans mount.
Post  cool40 on November 30th 2011, 11:01 pm
richter69 wrote:front and midplate here, no trans cross member or mount, my lateral limiters bolt where the tranny mount would have, and run back to the driveshaft loop................stock case glide here and taihousing.
i could'nt find a pic of the trans mount but it's same as yours.my front plate is the real wide one so i went with the extra limiters on the block.
Post  whatbumper on November 30th 2011, 11:32 pm
Of course with the setup that I mentioned you HAVE to run the limiters on it to stop the fore and aft movement that the plates would allow. Do not let the trans mount be the limiter.
Post  cool40 on November 30th 2011, 11:46 pm
whatbumper wrote:Of course with the setup that I mentioned you HAVE to run the limiters on it to stop the fore and aft movement that the plates would allow. Do not let the trans mount be the limiter.
lot of folks run without the limiters till they break it,lol.like me Embarassed the shorter plates like you'd use in a stock front half car dont have as much trouble.
Post  bcr466 on December 1st 2011, 1:13 am
Limiters will be on it regardless of which way I go. Be nice if I had some pics of some of yours to get an idea of different ways to trim and mount plates.
bcr466
Post  Curt on December 1st 2011, 9:16 am
I have always used front and rear plates with no transmission mount, with limiters.
