Eddy head 460 with icon pistons
+16
99zx9r
jm
gmsmkr
butterbean
quick 52
1fatcat
meandad
mudtrucker
5pointslow
20 posters
Page 3 of 5
Page 3 of 5 • 1, 2, 3, 4, 5
Re: Eddy head 460 with icon pistons
5pointslow wrote:IDT-572 wrote:5pointslow wrote:supervel45 wrote:I think I would still stick with the cam Blake recomended, and not push the hypers too hard.
stock rods ...i think put chip at 6300-6400 max and shift at 6k
Ok now nail it down and stick to it and have some fun....................
thats the plan keep it simple and all goes well should have this all set for start of next season ( hope before that ) our track closes in October
Atco is open through the first week of December.
Good luck with the build.
99zx9r- Posts : 39
been thrashing on car ......
bought a set of h beams to go with the KB hypers ( figuare rods be more forgiving)
should get 10.5 to 1 compression .
I have a viktor intake but could sell and get a tfs mafia if any gain could be had ? Trying to get most out of what i have for now but could sell intake i guess to get another one ..i dont know
heads are out of box eddy 75 cc .... going to get with someone to do a custom solid flat tappet cam to get the most of it.
550-575 hp is my goal
5pointslow- Posts : 1400
5pointslow wrote:been thrashing on car ......
Should have kept the stock rods and bought better pistons. Can yhey last? Yes, so long as it never rattles and the ring gaps follow or exceed kb direction. Seen a handfull of hypers in the pan, because street warriors doing cheap added hose.
kim- Posts : 700
No nitrous being used ....fyi
NA combos detonate too... just less dramatically, usually.
kim- Posts : 700
I agree ... I think i will be ok at this hp level and if i went with better pistons my luck id have rod failure ....i had the engine this pistons came out of and basicly over hauling it with a light hone . cylinders are near mint an mic up great
5pointslow wrote:I agree ... I think i will be ok at this hp level and if i went with better pistons my luck id have rod failure ....i had the engine this pistons came out of and basicly over hauling it with a light hone . cylinders are near mint an mic up great
Build it, beat it, enjoy it.
Some times we kill ourselves with how can we make it bullet prof, only to spend 1000's and still have something we outgrow, blow up, or just get bored with.
We all sit back and tell you how you could have, should have, etc....... yet, every lap you make, is one you made without our enlightened input.
Build what you have, best of luck, and enjoy.
kim- Posts : 700
kim wrote:5pointslow wrote:I agree ... I think i will be ok at this hp level and if i went with better pistons my luck id have rod failure ....i had the engine this pistons came out of and basicly over hauling it with a light hone . cylinders are near mint an mic up great
^^^^^^this.... and the best part is there will be time to upgrade and make it more when you get ready
gmsmkr- Posts : 1364
Looking for 10.00 to 10.50 to index race ....i really dont need a ton ...hell could use a small block if needed
Do you have the small block parts to make a 10sec build laying around?
gmsmkr wrote:Do you have the small block parts to make a 10sec build laying around?
No ...point was shouldn't take a ton of power at 2700-2800 lbs to go those times....... the eddy heads I have are cj cnc port openings to use to help the issue
Keep the Victor.5pointslow wrote:been thrashing on car ......
supervel45- Posts : 4453
need a sfi balancer .... prob will buy the ford racing one but will see whats out there first
https://www.429-460.com/t22928-turbo-547-bbf-project-part-out-idt-block-a460-heads-etc Did you see this one?
to this https://www.uempistons.com/installation_instructions/kb_installation.pdf
if my math is correct for drag race gasoline
.0329 top ring end gap
.016-.017 for second ring end gap
.002-.0045 piston to wall clearance
For a 4.390 Bore
For a 4.390 Bore
5pointslow wrote:gmsmkr wrote:Do you have the small block parts to make a 10sec build laying around?
I was getting at you have the parts to do a big block rock on with your plans...... it might just suprise you
Good luck have fun and keep us posted on how she does
seems the bbf surprises a lot of people with simple combos , i could build a crazier engine but to slow it down for the class ...no need
turning 27 in a couple months and paying for a wedding currently out of pocket for spring .......should call this the WEDDING BUILD lol
so trying to use some things i already have and will spend some but didnt want to build a new engine from scratch .
finished redoing my house i bought last year ....been busier than ever .
could go crazier but local class is 10.50 index thats pretty big class .....should be simple combo to get to work
My thing is a finding a good starting point TIMING for this engine with hyper pistons , will use vp113 even with the compression at 10.7 to 1 ...i have use dto it before and have had good luck with it being consistant .
Did you even call this guy and see what he will take for the Ford Racing balancer?supervel45 wrote:https://www.429-460.com/t22928-turbo-547-bbf-project-part-out-idt-block-a460-heads-etc Did you see this one?
Sent pm earlier
OK. I did not no if you had seen it, or his phone number in the long add.
supervel45 wrote:OK. I did not no if you had seen it, or his phone number in the long add.
Thanks I appreciate it
I know of a offy port o sonic for Dommy ..... I have a viktor but thinkin of grabbing it locally for 100 $
Not sure if any gain up to 6500 rpm max vs viktor , will probably grab for money though
Maybe only gain is stock hood with that Intake
Grab that intake now for a $100 dollars even if you don't use it, they are hard to come by and pretty good.5pointslow wrote:I know of a offy port o sonic for Dommy ..... I have a viktor but thinkin of grabbing it locally for 100 $
Guy is local next town over ...i can grab this week . if i recall i have seen some have good results with them .
I know the viktor is good , maybe the port o sonic with the 1050 will be better for my rpm range . not sure but im grabbing it
» New Eddy Heads?
» ICON Pistons
» Icon 4.500 pistons
» Bunch of Parts for Sale (DOVE block, headers, cam, rods, misc)
» icon forged pistons
» ICON Pistons
Page 3 of 5
