QA1 Shock Issue
QA1 Shock Issue Empty QA1 Shock Issue
Post  gdog May 24th 2012, 9:25 pm
We were starting to work on the car and I noticed that on one front shock the body of the shock was clear up in the shock tower. The other side was showing serveral inches of rod. Any ideas of what I need to look for?
thanks,
Gordon
gdog
gdog
QA1 Shock Issue Empty Re: QA1 Shock Issue
Post  cool40 May 24th 2012, 9:56 pm
is the shock still bolted down on the bottom? its a torino? same as a 69-70 mustang aint it?
Post  gdog May 24th 2012, 10:10 pm
I will Check
G
gdog
gdog
Post  crittersf1 May 25th 2012, 12:05 am
Is the Question Question Question car sitting level side to side?
crittersf1
crittersf1
Post  DILLIGASDAVE May 25th 2012, 1:29 am
Theoretically if both front shocks are exactly the same (body/shaft/travel lengths), and the top & bottom mounts are the same side to side, and the car is sitting level side to side, then there should be at/around the same amount of shock shaft showing each side.
I know that the front shocks of a 70 Ranchero (same as Torino???) & 69 Mustang I had weren't the same. The top mounts were different & I think the total travel might have been different between the two cars. The 71-73 Mustang had similar top mounts to the 70 Ranchero, but one had a shorter total shock length/travel than the other, (I think the Stang was shorter).
Post  gdog May 25th 2012, 8:31 am
Thanks to all. I will get underneath it tonight to take a good look.
The car is on the level.
Gordon
gdog
gdog
Post  whatbumper June 20th 2012, 12:53 pm
everything check out okay?
Post  crittersf1 June 21st 2012, 12:53 pm
I guess we'll see tomorrow at the track.
crittersf1
crittersf1
