got my 1962 home
johndickjr
Page 1 of 2
Page 1 of 2 • 1, 2
got my 1962 home
got my 1962 falcon home, it has a 300 ci straight 6 in it, previous owner really had some things way off..fuel system is ran wrong..fuel pump and filter are higher then the cell..battery is ground to sheet metal in truck..has wrong flexplate on it..things like that..going to run this motor till then breaks and maybe do a large ci sbf later
johndickjr- Posts : 896
Re: got my 1962 home
i like it.
Wait till Red see this..................
I like it.
I like it.
That Looks Like a whole lot of fun.
i got flywheel changed/..put a 800 Holley on it, got fuel system all redone, ready to race tnt Friday night, sounds good for a straight 6
Get some video!
Cool car.
jasonf- BBF CONTRIBUTOR
LOVE LOVE it !!!! I even love the tower of power! Let us know how it runs! ---RED
61coon- Posts : 1824
whats the tower of power?61coon wrote:LOVE LOVE it !!!! I even love the tower of power! Let us know how it runs! ---RED
johndickjr wrote:whats the tower of power?61coon wrote:LOVE LOVE it !!!! I even love the tower of power! Let us know how it runs! ---RED
The mighty 300 six. If it were a dodge slant 6,it would be the leaning tower of power.
ok..yes they are long sob that is for sure..this one has a 800 holley on it, intake and header are home built 1-3/4 tubes on both..12-1 compression..roller rockers, 4.56 gears in a 9 inch..4500 bte converter built c4 with t brake..head is ported with normal mods..big valves etc..solid cam ,61coon wrote:johndickjr wrote:whats the tower of power?61coon wrote:LOVE LOVE it !!!! I even love the tower of power! Let us know how it runs! ---RED
Those "big block" 300's are some pretty tough engines. I'm really looking forward to hearing the results from your trip to the track this weekend.
Check this out, pretty neat article
http://www.carcraft.com/featuredvehicles/ccrp_1108_1971_ford_maverick/viewall.html
i have seen that , pretty cool, i though about a 347 or 408 but those are everywhere, maybe a mp t70 next year, i would have to yank pistons and stuff..right now i just want to enjoy it..last time out the previous owner ran a 9.0 1/8 mile..with the issues it had, it would not go past 5k rpm, , and the throttle was only about 1/4 way open, it has a billet 2 piece lokar gas pedal, and cable(piece of shit) i fixed that. i played with it in the drive and hit 6500 easy.if it goes a true 13.00 1/4 mile..ill be happy anything faster is that much better61coon wrote:Those "big block" 300's are some pretty tough engines. I'm really looking forward to hearing the results from your trip to the track this weekend.
6 cylinder are cool and different. An old neighbor of mine had a early 60s Chevy 2 with a worked over 250 in it, it sounded wild and ran pretty damn good for what it was.
not to bad, that was the first time in 6 years ive been down track, first pass 2.05 60ft--14.90 1/4 mile@86mph..left line and like a dork forgot to put tranny back in 1st gear..2nd pass , pos shifter , if your hand is touching it it will go to 2nd gear..but got better 2.0 60ft---14.49 @89...3rd pass i forced my self not to touch the shifter till its was time to shift, and i did not succeed..hit 2nd about 4000 rpm,,and then bumped it back into 1st and stood on it..went 14.024@89mph with a 1.83 60ft...then noticed my gas pedal is bent and hitting the floor none of the pass was full throttle..so not bad, once bugs are worked out and seat time i think 12.50s are in it, and get a smaller carb, the 800 is just to dam big
had a bad vibration , so i tore motor done, taking it to machine shop..i found a broken timing gear but car still ran, i thought the timing was acting funny when i was setting timing..and it has the wrong pistons in it, the pistons that are in it are 240 pistons and are .230 in the hole..for a whooping my binding 7-1 compression..cam starts pulling at 3000 and stops at 6000..so if i put more cam in it and some 351w pistons to get the compression up, it should run pretty dam good for a 6 banger
I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
i was shocked that i got a 1.83 60ft ..then discovered it has 7-1 compression...with the piston ill put in it and cam, it should run 12.00IDT-572 wrote:I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
johndickjr wrote:i was shocked that i got a 1.83 60ft ..then discovered it has 7-1 compression...with the piston ill put in it and cam, it should run 12.00IDT-572 wrote:I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
I'm sure it will run that, I was amazed at the power the engine we did made.
took it to get balanced..crank was 25 grams off...flex-plate was trash..not sure if it was like that before or after..he got crank rods and all withing 1/2 gram..so it should be good to go
how did that work ? always wondered how a dome on a 351w will fit the inline head cause of the valve angle compared to the dome angleIDT-572 wrote:I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
johndickjr wrote:how did that work ? always wondered how a dome on a 351w will fit the inline head cause of the valve angle compared to the dome angleIDT-572 wrote:I did one several years ago with 351 hyper kieth blacks with .100 dome and a ported 240 head. It was hard on the stock rod brgs but it was a power house. turned it 7000-7200 every run.
I can't remember the exact dome height, but the volume was 5 cc and It had plenty of valve to piston clearance with a .650 lift cam and dur @ .050 around 260 on a 104 sep Trying to remember specs off the top of my head. but there close.
You can always get some custom slugs made.
dont want to spend that much , not trying to sit the world on fire, looks like dome top 351w pistons will work ..it will be between 11.5--12 compression depe nding on my cc of head mand not sure if deck has been cut..at a bare min 11.5 compared to the 7-1 it is now..heck that probally close to at least 50-75 hp..i hopedfree383 wrote:You can always get some custom slugs made.
just bought a set of trw dome pistons, will give me 11.5 compression, stay tuned,,may get new cam also
Page 1 of 2 • 1, 2
» Home sweet home, Back from the chassie shop
» 62 Galaxie for sale
» 1962 Ford Fairlane 25.5 Project
» 1962 falcon front suspension
» 352 FE 1962 Ford Donated High School Auto Shop Engine
Page 1 of 2
