429 ford
429 ford
hey guys i am building a 429. can t find a 460 crank around here. but i do have a set of 440 mopar rods.what is invoved in putting 440 rods and 460 pistons in with the 429 crank?what stroke would it be? i know i would have to have the rod journals cut down to mopars size. and i would have to get small ends bushed to accept the ford pins. i am guessing everything would have to be balanced.how much trouble would it be? how many ci. thanks
james00- Posts : 14
Re: 429 ford
You could get a 4" crank throw easily froma 429 crank by offset grinding it. 429's have a 2.5" journal and a 3.59" stroke. The Dodge rods are 2.25" journal. By offset grinding to a 2.25" journal you can add up to a .5" longer stroke to a crank. This was done a lot before there were larger stroke cranks readily available. Adney @ Performance Crankshaft probably has some offset ground 460 cranks on the shelf that would use more common components. Give him a call and make it a little easier on yourself IMO
schmitty- Posts : 4538
Re: 429 ford
schmitty wrote:You could get a 4" crank throw easily froma 429 crank by offset grinding it. 429's have a 2.5" journal and a 3.59" stroke. The Dodge rods are 2.25" journal. By offset grinding to a 2.25" journal you can add up to a .5" longer stroke to a crank. This was done a lot before there were larger stroke cranks readily available. Adney @ Performance Crankshaft probably has some offset ground 460 cranks on the shelf that would use more common components. Give him a call and make it a little easier on yourself IMO
Mopar rods are 2.375" journal NOT 2.250" journal ... that is Pontiac or Oldsmobile.
Re: 429 ford
james00 wrote:hey guys i am building a 429. can t find a 460 crank around here. but i do have a set of 440 mopar rods.what is invoved in putting 440 rods and 460 pistons in with the 429 crank?what stroke would it be? i know i would have to have the rod journals cut down to mopars size. and i would have to get small ends bushed to accept the ford pins. i am guessing everything would have to be balanced.how much trouble would it be? how many ci. thanks
With what you wish to do with a 1.755" compression height OEM 460 piston would have the same stroke as a 429 at 3.59" therefore it would be the same cubic inch engine.
Kinda stupid for the cost outlay.
Re: 429 ford
My bad, I had .25"stuck in my head, and that would have been added stroke, not difference in journal size:rmcomprandy wrote:schmitty wrote:You could get a 4" crank throw easily froma 429 crank by offset grinding it. 429's have a 2.5" journal and a 3.59" stroke. The Dodge rods are 2.25" journal. By offset grinding to a 2.25" journal you can add up to a .5" longer stroke to a crank. This was done a lot before there were larger stroke cranks readily available. Adney @ Performance Crankshaft probably has some offset ground 460 cranks on the shelf that would use more common components. Give him a call and make it a little easier on yourself IMO
Re: 429 ford
Dad and I did this back in the mid 80's...My first big block
But the max stroke is 3.975, used a 6.770 Mopar rod, with a 4.50" bore is 506"
QtrWarrior- Posts : 2698
Re: 429 ford
QtrWarrior wrote:schmitty wrote:You could get a 4" crank throw easily froma 429 crank by offset grinding it. 429's have a 2.5" journal and a 3.59" stroke. The Dodge rods are 2.25" journal. By offset grinding to a 2.25" journal you can add up to a .5" longer stroke to a crank. This was done a lot before there were larger stroke cranks readily available. Adney @ Performance Crankshaft probably has some offset ground 460 cranks on the shelf that would use more common components. Give him a call and make it a little easier on yourself IMO
YEP ... that was pretty normal before you could just buy everything for a stroker engine. That also did require a custom 1.56" compression height piston.
Re: 429 ford
james00 wrote:so what would it take to get a longer stroke?
460 crankshafts are not hard to find. If you cannot find one you are not looking. If you want a stroker plenty of sources for all that stuff, just need to look around and don't need to look to far at that. Off set grinding a 429 crank and using those Mopar rods will end up being more expensive. Guys did things years ago that we don't do today as they had not much choice in off the shelf stroker stuff like today. Take advantage of what is available today would be my advice.
466cj- Posts : 391
» We had a forum member set low ET for a Ford at the Annual Ford v Chevy race last weekend.
» Let's see your "unusual"Cool HotRod pic's. Ford and Non Ford
» mad dog headers off a 79 ford work on a 84 ford?
» big block ford parts,and sb ford
» FS: 1967 Ford Custom 2 door sedan with '67 Ford Custom parts car (Galaxie body)
