dove blk splayed 4 bolt.
i had it sonic tested and it was capable of a 4.5bore which it is now freshly machined and never ran.
was going to run a stk blk class and changed my mind.
specs as follows .
4.5 bore.
new wide cam bearings.
pro gram endineering4 bolt caps on 2 3 4 mains ,arp studs .
half fill hard block.
decked very little .007
align honed for .003 clearance, includes new main bearings.
usual oil mods.
I have way more money than a guy should in a stk blk lol!
drop in your rotating assy and go.
$1100+ ship or avail as all forged 14-1 585ci shortblock setup for A460 heads if interested.
may take partial trade on a new style tfs A460 4bbl intake.
im in ohio
specs as follows .
4.5 bore.
usual oil mods.
im in ohio
bbfstanger- Posts : 221
Re: dove blk splayed 4 bolt.
forged 4.600 stroke crank
4.5 bore custom racetek 14-1 domed pistons for A460 heads
heavy duty pins
eagle 6.8 rods with L19 bolts
wide cam bearings from Lem
h series rods and mains.
plasmamoly rings
internal balance with jw wheel and fms balancer
its still assembled I had the shop assemble it too.
includes block listed above
$4900 shortblock assembled
or $1100 for the block and main bearings.
$1000 no bearings
honestly id rather just sell the block
937 561 0262
john
heavy duty pins
plasmamoly rings
$1000 no bearings
937 561 0262
john
Where are you located? Thick web (bulkhead) mains?
jbozzelle- Posts : 3660
im in springfield ohio.
i forgot to mention it does have one sleeve ,there was a blemish in the cyl.. so it was fixed.
yes it does have the thick bulkheads.
I can give the engine builder no. if someone wants it.
