Who is running C460 heads and turbocharged?
Who is running C460 heads and turbocharged? Empty Who is running C460 heads and turbocharged?
Post  E-Works on February 2nd 2016, 10:23 pm
Just seeing who is running a turbocharged application with C460 heads?
Maybe pick your brain a little bit.
Aaron
E-Works
Who is running C460 heads and turbocharged? Empty Re: Who is running C460 heads and turbocharged?
Post  garys gt on February 2nd 2016, 11:06 pm
I would like to see some applications with the profiler heads and twin turbo. Curious to how much power can be made.
garys gt
Post  E-Works on February 2nd 2016, 11:17 pm
604 CI C460 Headed A/R solid aluminum block with single 118 here......
New combo for us after maximizing our little 8.2 sbf for years....
Grudge car
E-Works
Post  garys gt on February 2nd 2016, 11:42 pm
E-Works wrote:604 CI C460 Headed A/R solid aluminum block with single 118 here......
Grudge car
what kind of horsepower does something like that make if you can say.
garys gt
Post  E-Works on February 2nd 2016, 11:42 pm
4k
E-Works
Post  garys gt on February 2nd 2016, 11:46 pm
Is that the profiler heads or a different c head.
garys gt
Post  E-Works on February 14th 2016, 1:37 am
Motorsports C head
E-Works
Post  windsor on February 15th 2016, 6:59 am
E-Works wrote:4k
Who is running C460 heads and turbocharged? 69fbf7240f42620c870bdc173856ead82781e930db2ac505e941931fc2c24ea1
Post  garys gt on February 15th 2016, 12:01 pm
windsor wrote:
E-Works wrote:4k
that must have a good amount of boost for 4k. That boost is some powerful stuff. I seen a guy with a big inch ford falcon and a large turbo at our local track running bounty race I believe.  It ran good but took a while to build boost. Beautiful car. Don't know horsepower numbers he had or how much boost but it was alot.that thing was spitting and popping and snorting up to the line.
garys gt
Post  E-Works on February 17th 2016, 2:37 pm
Boost is all relative on how efficient your engine flows.....
My 20 lbs might be your 40 lbs or vice versa
Remember and engine is just an air pump
E-Works
Post  IDT-572 on February 17th 2016, 5:53 pm
E-Works wrote:Boost is all relative on how efficient your engine flows.....
And boost is a measurement of restriction
Post  procharger 528 on February 21st 2016, 8:49 pm
i have a 572 with c heads running a procharger not sure on the horse power but it runs 6.9 @ 200mph in a 3300lb car....on a rich tune 42lbs boost at the end of the track...
procharger 528
procharger 528
Post  E-Works on February 22nd 2016, 1:04 am
We ran our 360" sbf for a many years but the past 3 just 1/8 mile.
It is a grudge car so i won't give too much info but we ran right at about 28-30 lbs of boost and rhe car is 3k even loaded.
It made about 2100 hp
E-Works
Post  procharger 528 on February 22nd 2016, 2:18 am
so at a guess i have to at least 2000hp...cool Cool
procharger 528
procharger 528
