SK 429 intake
SK 429 intake
someone mite want it.
http://www.ebay.com/itm/RARE-Ford-429-460-2x4-Experimental-Aluminum-Intake-SK-42855/251288795129?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35625%26meid%3D0
res0rli9- BBF CONTRIBUTOR
Re: SK 429 intake
Yea keep teasing me ResOrLi
https://www.dropbox.com/s/ez36bqw6raszn9r/2016-03-21%2022.32.25.png?dl=0
https://www.dropbox.com/s/mc6xhirzex6cmtl/2016-03-21%2022.32.28.png?dl=0
$950.00 with carbs, linkage, aircleaner, and fuel log. Let me know if you want it and I will have them call you. Tipped from a member at 460.com.
supervel45- Posts : 4453
Re: SK 429 intake
http://www.ebay.com/itm/NOS-429-NASCAR-Holman-Moody-BOSS-429-dual-dominator-spider-intake-assembly-Dport-/222061143536?hash=item33b3e025f0:g:ZSUAAOSwX~dWrSGI&vxp=mtr
Re: SK 429 intake
supervel45 wrote:http://www.ebay.com/itm/NOS-429-NASCAR-Holman-Moody-BOSS-429-dual-dominator-spider-intake-assembly-Dport-/222061143536?hash=item33b3e025f0:g:ZSUAAOSwX~dWrSGI&vxp=mtr
That's cool, I don't know if it's $7,000 cool though.
68formalGT- Posts : 864
Re: SK 429 intake
68formalGT wrote:supervel45 wrote:http://www.ebay.com/itm/NOS-429-NASCAR-Holman-Moody-BOSS-429-dual-dominator-spider-intake-assembly-Dport-/222061143536?hash=item33b3e025f0:g:ZSUAAOSwX~dWrSGI&vxp=mtr
X2
Re: SK 429 intake
Yea the price knocked me out of the chair too but, it is a cool intake. You should look at some of the guys other stuff, pretty interesting also.
Re: SK 429 intake
It is a "fabricated " manifold made out of a Boss 302 intake grafted to the Boss base.
gt350hr- Posts : 662
Re: SK 429 intake
res0rli9 wrote:someone mite want it.
That intake was designed in Dec '68 when Ford was considering using the 429 wedge in Nascar . This was the small port version for the 366 ci engine and the large port was for the 429 ci engine. Also designed around that time was the aluminum wedge head. All were dropped when the move was made to run the Boss 429 as it made bigger power . The Blue thunder is made of of the original paterns and is less expensive. Holman Moody put their name on them as well and used them on marine engines they sold. It is a good running manifold.
Re: SK 429 intake
[quote="gt350hr"]
That intake was designed in Dec '68 when Ford was considering using the 429 wedge in Nascar . This was the small port version for the 366 ci engine and the large port was for the 429 ci engine. Also designed around that time was the aluminum wedge head. All were dropped when the move was made to run the Boss 429 as it made bigger power . The Blue thunder is made of of the original paterns and is less expensive. Holman Moody put their name on them as well and used them on marine engines they sold. It is a good running manifold.[/quote
Wish the guy
would answer his pm's. He has been trying to sell that SK intake on and off for a while I think as I have seen it before and linked it myself here. The only reason I would pay more for it is then a BT is the SK part number and the Buddy Bar on it, but would not mind having it over a BT because of the rarity.
Wish the guy
Re: SK 429 intake
This pretty cool also... I'd rather have it then the intake.
http://www.ebay.com/itm/NOS-429-NASCAR-Holman-Moody-BOSS-429-magnesium-alum-dry-sump-assembly-complete/222061717300?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36188%26meid%3D7c6b627234e64ff6ae09dd46d748c3f8%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D222061143536
Re: SK 429 intake
supervel45 wrote:Yea keep teasing me ResOrLi
I got one in my bed room like it... All complete factory set up with new carbs that I only payed $ 750.00 for.
Re: SK 429 intake
Rub it in buddy, LoL. I saw the other part too in his listings is why I mentioned to check out his other stuff, it is pretty cool also but, I don't need that on the truck for sure. I would probably chance running the SK intake though, but it should probably be on the mantle for show and tell.
Re: SK 429 intake
Supervel45,
The guy's name is Chris and I see him at local swap meets so I'll get a phone number for him and forward it to you.
Re: SK 429 intake
gt350hr wrote: Supervel45,
Thanks, I even called Paul Kane trying to track him down but, he does not know him at least by his company name. He's looking for a BT for me also. Want to buy his 498"? 14K
Re: SK 429 intake
Whats the rpm range on the sk intake?
duff429- Posts : 202
Re: SK 429 intake
The small port version is good to 7,500 the big port ( different SK #) was good for 8+ but was bad in the midrange compared to the small port.
Re: SK 429 intake
I have one that was on my car but the number was ground off.il have to measure the openings
Re: SK 429 intake
duff429 wrote:I have one that was on my car but the number was ground off.il have to measure the openings
How much do you want for it if it is for sale? I am kind of holding out for the CJ flange but the Ebay deal looks like it's a standard port also.
Re: SK 429 intake
Im gonna hang on to it for another 10 years i think
Re: SK 429 intake
The ebay unit is a standard port version. It is at the local swap meet every month.
Re: SK 429 intake
gt350hr wrote: The ebay unit is a standard port version. It is at the local swap meet every month.
Likely
going on ported Doves or PI heads on engine #2. I think it might work with the PI's but, for the rairity of it I could never bring myself to open the ports up and would likely have to go with the Dove heads if I scored that intake. My D2's are not fully opened up either and it would likely seal on them also, if I stuck it on the current 429. Hope you can get his number soon as I need to get on with it, or explore other options or stick with what I already have.
Re: SK 429 intake
PS: I almost pulled the trigger on the DSC BTCJ but, luckly he did not answer the phone for my wallet.
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» New Ford Racing Performer RPM intake ported and NIB Victor intake for Dominator
» OFFENHAUSER TURBO-THRUST 360 POWER PORT For Sale
» Victor 460 Intake Manifold FOR SALE
» Enderle complete set up no intake or 1200 with intake
