Starter issues w/TCI midplate.
Was just wondering if anyone has had any starter meshing issues w/TCI midplate. I have fought this as long as I've had this car. I've been contemplating taking it out and sending it to KFM for a new one.
Re: Starter issues w/TCI midplate.
Rick,was this the problem you were having at Norwalk?
Mark Miller- Posts : 1888
Hopefully you get it figured out.
Rick, Russ Hood and David Willingham are working out Russ's starter problem as we speak.
Russ Can send you some pictures I'm sure if you ask him.
I would be glad to send pics. Just give me your cell. . Ive fought them all year.
Here are a couple of things to check.
Mock the starter and mid plate on an engine with the Flexplate that you are using.
Pull the starter pinion "out" in the engaged position and block it there. I usually put a couple tie wraps around the small part to make it stay out.
Now you can check your engagement depth and tooth backlash.
Most starter guys recommend between.015" and .040" tooth clearance.
If your pinion is not coming all the way across the ring gear tooth, that needs to be addressed.
There seems to be a wide variation on offsets when aftermarket Flexplates are made.
An easy way of checking the accuracy of the starter register hole is to stack an OE starter locator plate on it, using the dowels to align the plates.
If the starter fits loosely in the register hole ( the 4.091 ish one) you will experience problems.
I hope this helps.
Keith
I hope this helps.
Keith
Is that clearance between the end of the starter gear cog where it meshes with the flexplate gear?
Wheelie58 wrote:Here are a couple of things to check.
I hope this helps.
Keith
Thanks Keith
Moodyblues wrote:I would be glad to send pics. Just give me your cell. . Ive fought them all year.
You have pm Russ.thx bro
» 460 starter issues
» Powermaster starter issues
» 460 starter/flexplate issues
» Starter wiring , with solinoid on starter and fender
» My midplate troubles.
