Need some help identifying a problem
Got the truck out at the track and while warming it up it just didn't sound right. I got my inferred temp sensor out and the no 6 header tube was quite a bit hotter and the no 8 was cooler then the rest. This is a mech injection deal. Any ideas for me to start checking?
Re: Need some help identifying a problem
Make the dot on the injector is facing the right way make sure the pill or vacuum holes is not stopped up.
Pull nozzles and clean them.
If they have junk in them, pull the fuel tank and clean it out.
10.0- Posts : 54
» I need some help identifying an engine block
» Need help with identifying a block
» Help identifying these heads.
» Help Identifying carb 1050?
» identifying unknown piston
