water pump issue bolt length mezierre
well im having an issue
my last thing im doing to engine before bringing to dyno on Saturday morning is to put the water pump on
I put backing plate on and then the pump , the stainless allen cap bolts are 4 inches long and all four of them come up to long by 1/4-3/8 of an inch to long and stop if i go more they feel like they will break . not sure if any of you guys have had this issue and it gets me there all exactly the same
im bringing a tap extension home today from work with a new tap and see if holes in block are not clean , the machine shop who did my machine work said they re chased all threads when cleaning block
5pointslow- Posts : 1400
Re: water pump issue bolt length mezierre
Shorten the bolts?
maverick- BBF CONTRIBUTOR
If you're planning on using an engine plate then they are the correct lenght
D. Sea- Posts : 2768
D. Sea wrote:If you're planning on using an engine plate then they are the correct lenght
im not using an engine plate
maverick wrote:Shorten the bolts?
this is what im going to be doing , but was not sure if anyone else had this issue
i see on there site they sell spacers ....maybe thats what i needed all along and did not know
» Kaase pump canton pan...issue
» Head Bolt and water jacket sealant ?
» Switched from mech water pump to Moroso electric water pump
» 460 Water Pump Crossover Tube that goes in the Intake to the Water Pump?
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
