Oil pump prime tool
BigDave65
kjett
mach1charlie
Oil pump prime tool
Any know of a store bought tool, like a distributor with the gear off to prime a 460?
mach1charlie- Posts : 38
Re: Oil pump prime tool
mach1charlie wrote:Any know of a store bought tool, like a distributor with the gear off to prime a 460?
I use a deep, thin wall 5/16" six point socket epoxied to a 6" extension.
rmcomprandy wrote:I use a deep, thin wall 5/16" six point socket epoxied to a 6" extension.
^^ This! works like a champ.
kjett- Posts : 1169
I've got a store bought one a friend gave me a long time ago. No idea who made it but it's just a length of rod with the 5/16 hex formed in one end. Basically the same thing Randy described only one solid piece.
BigDave65- Posts : 567
If I remember correctly, Moroso used to sell them.
pmrphil- Posts : 170
rmcomprandy wrote:mach1charlie wrote:Any know of a store bought tool, like a distributor with the gear off to prime a 460?
I have a deep thin wall 5/16'' 1/4'' drive on a old extension black taped on I use in my 1/2'' drive drill I do need to epoxy like Randy said it on I have had it to come off and what pain to get out.
I checked this AM, Moroso still sells them, part #62220 for 351W/460, and 62210 for 302/FE
Meh, I just took the low buck approach & took the center shaft out of an old dizzy & used it to prime with a drill vs buying one.
DILLIGASDAVE- Posts : 2262
you do not need a drill, any old speed/bent handle crank wrench works. zbob
zbob- Posts : 269
» Oil pump won’t prime
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
» maintence finds .....
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
