Cometic MLS Exhaust Gaskets Port size suitable ? or best option ?
Gregaust
bigblockfordfxstb
Afternoon,
In the process or ordering parts (Ordering from Summit, in Australia so ordering number of parts from one supplier, $$$$ for freight from various suppliers.
Have have bad experience in the past from exhaust gasket leaks, and its such a tight fit its not practical to be simply removing them to replace or check, so want to do it one time only. Have read tons of comments but 2 many options and suggestions.
I see these Trickflow MLS gaskets but the port size on them vs mine are larger. I got a response from Trickflow they said ' should work fine' .
My Ports 2.055 H x 1.406 W
TFS-53490931 2.350 H x 1.550 W (.030 thick)
Is this just a bad idea ? should I stick with matching port size gaskets ? Do these also need a sealer to apply them ?
Thoughts ?
R
Normally Aspirated
Cast Dove Head
Aftermarket Headers have been check for straightness and cleaned up
https://www.summitracing.com/int/parts/tfs-53490931/overview/
Thoughts ?
R
Normally Aspirated
Cast Dove Head
bigblockfordfxstb- Posts : 125
Re: Cometic MLS Exhaust Gaskets Port size suitable ? or best option ?
Copper Hi temp silicone , no gasket. I always used to use gaskets but then switched over . That's how I do all mine now
Gregaust- Posts : 620
Curt- Posts : 2787
Hi,
So no gasket at all straight silicon system ?
I guess you apply and all bolted up before it being set, problem is I have less than 1/4inch gap to try do anything, its real tight....
R
R
Gregaust wrote:Copper Hi temp silicone , no gasket. I always used to use gaskets but then switched over . That's how I do all mine now
Curt wrote:Red RTV.
I know a lot of people use these methods and I have used it on my cobra headers but it is nasty and looks like crap if that is a concern. Also for a tight space I can see that being difficult to apply. I use the Felpro racing gaskets and have had good luck. You just have to make sure your bolts stay tight and they will last. Any gasket will blow out if the bolts come loose. Throw some teflon tape on your header bolts and it will work like loctite but you can still get them out without too much difficulty. I have also used the stage 8 locking system on my cobra and I have haven't blown a gasket since.
jasonf- BBF CONTRIBUTOR
Thanks Jason Will check then out.
On the race car I just use straight red RTV because it's easy with my tubes being installed one at a time, works great. But on the small block street car I used Percy's "Seal For Good" gaskets. They also have a version called "Graph-Flex", I haven't tried that one yet. You can also order their "XX Carbon" in sheet form and cut your own. I think any of the three are available thru Summit.
Hi Doug,
Have seen a few people rate the Percy gaskets. Ill check them out thanks for feedback to you and other guys also!
Rob
Rob
Doug Rahn wrote:On the race car I just use straight red RTV because it's easy with my tubes being installed one at a time, works great. But on the small block street car I used Percy's "Seal For Good" gaskets. They also have a version called "Graph-Flex", I haven't tried that one yet. You can also order their "XX Carbon" in sheet form and cut your own. I think any of the three are available thru Summit.
I run the Percy on my Ranger they have held up great I have even reused them also without a issue. I will keep on using them on the Ranger and the next time I have to replace the ones on my 69F100 be Percy. They are the best header gasket I have bought.
Ok found these on Summit. Slightly smaller port width, only bad thing is not in stock for a few week. Would order else where but have a number of orders with them to keep shipping to a minimum as its a killer at $90+ a pop and we have to keep below 700$us + freight (keep under $1000 Aus) we are then hit with Duty Tax on top.. not that you wanted to know that !
I take that i can clean up the gasket to match my width or will that break its seal?
Part 67035
Gasket Material: Graphite coated steel core laminate
Port Height (in): 2.060 in.
Port Width (in): 1.380 in.
Part 67035
bigblockfordfxstb wrote:Ok found these on Summit. Slightly smaller port width, only bad thing is not in stock for a few week. Would order else where but have a number of orders with them to keep shipping to a minimum as its a killer at $90+ a pop and we have to keep below 700$us + freight (keep under $1000 Aus) we are then hit with Duty Tax on top.. not that you wanted to know that !
Part 67035
I trimmed the corners of the "Seal for Good" gaskets so the radii matched better with no side effects. I would imagine you can trim the "Graph-Flex" also.
» Exhaust port flow vs. header size
» Speedmaster 460 Head Exhaust port size
» I got my cometic gaskets now what???
» cometic mls gaskets
» cometic gaskets
» cometic gaskets
