Deleting fuel pump concentric ring
Deleting fuel pump concentric ring Empty Deleting fuel pump concentric ring
Post  75truck March 10th 2017, 12:22 am
Building a 429.  I'm thinking of deleting the mechanical fuel pump ring that goes on the cam gear.
I am running a electric fuel pump to supply the Fitech FI carb.
Do i just remove the concentric and bolt the cam gear on?  Any adverse effects from doing this?
Bob
Tucson
75truck
Deleting fuel pump concentric ring Empty Re: Deleting fuel pump concentric ring
Post  FalconEh March 10th 2017, 1:08 am
75truck wrote:Building a 429.  I'm thinking of deleting the mechanical fuel pump ring that goes on the cam gear.
Bob
Tucson
Using a carb and switching to electric I usually left the FP concentric ring in place as a road side fix if need be, but with FI it likely won't help, so as far as I know the only adverse affects will be if the cam bolt bottoms out without the concentric spacer and torques the threads.
Deleting fuel pump concentric ring Empty Deleting FP Ring
Post  75truck March 10th 2017, 1:25 am
Good point I'll check the depth.
Thanx
Bob
75truck
