Aluminium Blocks 4.6150 Bore
Hi All,
Being in Australia aluminium blocks are not too easy to come by.
My current block is a water jacketed CandC via Jon Kaase.
Asking advice on whether any forum members deals with these or similar blocks (BF Evans?) , or should I go direct to CandC (contact?) or via Cliff at JKRE?
Any advice welcome.
Current combo went 7.4 with a 1.054 60' , foot braked C6 . Still greedy
Any advice welcome.
Last edited by WDR460a on April 29th 2017, 2:27 am; edited 2 times in total (Reason for editing : Forgot to sign off.)
WDR460a- Posts : 3
Re: Aluminium Blocks 4.6150 Bore
Had goodluck with C and C, they can do some of the machine work there too, clearance for crank and rods, rough bore, linehone, needle cam bearings, etc.
10.0- Posts : 54
Thanks 10.0 , my current block came from candc via JKRE . They are OK to deal with direct?
WDR460a- Posts : 3
Yeah Carroll Carter is the guy making the C and C blocks
They have a website C and C Motorsports.
10.0- Posts : 54
Yes C&C is fine to deal with direct.
» timing chain for aligned bore blocks?
» Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
» C6 Aluminium pan
» Ar aluminium block Question..
» Mechanical aluminium water pump
» C6 Aluminium pan
