Pistons broke at valve reliefs. Any ideas
nickpohlaandp
cobra501
Pistons broke at valve reliefs. Any ideas Empty Pistons broke at valve reliefs. Any ideas
Post  cobra501 October 16th 2017, 12:28 pm
This is my buddies engine. Only 5 runs on grudge 521 deal. Two pistons broken and rest cracked at the valve relief. These are Diamond pistons. Looking for answers so he can decide what direction to take. He only hit it with a 350 shot. He found problem during normal inspection.  Engine was running fine before teardown. He did experience a backfire.
cobra501
cobra501
Pistons broke at valve reliefs. Any ideas Empty Re: Pistons broke at valve reliefs. Any ideas
Post  nickpohlaandp October 16th 2017, 12:33 pm
cobra501 wrote:This is my buddies engine. Only 5 runs on grudge 521 deal. Two pistons broken and rest cracked at the valve relief. These are Diamond pistons. Looking for answers so he can decide what direction to take. He only hit it with a 350 shot. He found problem during normal inspection.  Engine was running fine before teardown. He did experience a backfire.
Sometimes the most obvious questions still need to be asked... is your buddy sure he had the ring gap set right? I've seen too tight of a ring gap pull the top off many pistons once you spray the gas on em.
nickpohlaandp
Post  cobra501 October 16th 2017, 1:02 pm
I should have thought of that. Good point. I will let him know and from there. Thanks.
cobra501
cobra501
Post  rmcomprandy October 16th 2017, 3:25 pm
Detonation or not enough ring end gap or maybe both.
Post  lance flake October 16th 2017, 4:50 pm
Is the 2nd ring pinched in the ring land? What does the skirt look like scuffed?
lance flake
Post  cobra501 October 16th 2017, 5:54 pm
If someone will PM me your phone number I will text you two pics and some more tonight when I get them. I never could upload pics here.
cobra501
cobra501
Post  gt350hr October 16th 2017, 6:48 pm
If the intake valve relief machining left a "wall" , the cylinder pressure spikes caused that wall to flex and the piston cracked at the inside radius of the ring groove. IF the valve notch machining broke through that "wall" , the lateral pressure would be reduced and the failure could be rings butting as Randy mentioned. That is the "cooler" side of the piston and is not known for detonation until a section breaks out and the hot ring causes localized melting of the surrounding area. Detonation would "normally " appear around the top ring land and usually on the exhaust side. It creates a texture like shot peening. Pictures will help the diagnosis.
gt350hr
Post  cobra501 October 16th 2017, 8:00 pm
https://s13.photobucket.com/user/cobra501/library/?sort=3&page=1#
cobra501
cobra501
Post  cobra501 October 16th 2017, 8:26 pm
I tried posting a pic. No luck so far. I got more pics lastnight and they tell a better story than he described. This damage has to be improper ring gap. Pics show that the area above the ring groove is busted from a ring bind. This was new motor and 1300 spent on a new set of pistons.
cobra501
cobra501
Post  cool40 October 16th 2017, 10:13 pm
No pics.....private
Post  Mark O'Neal October 17th 2017, 3:50 am
On the outside by the intake pocket?
Lean
Mark O'Neal
