Afr 315 flow numbers
Looking for flow numbers for afr 315 #3838 heads, I know there numbers are posted on the afr site , seeing if someone has flowed them
Steve-oh- Posts : 59
scroll down
Not exactly what you might want but I had my afr 280s flowed by an independent guy the results are below ,Doug
manofmerc- BBF CONTRIBUTOR
Re: Afr 315 flow numbers
Not sure if this helps this was fairly old back before they changed the CC naming from 300 to 315.
https://www.dragzine.com/tech-stories/engine/tech-deep-dive-air-flow-research-bullitt-cylinder-heads-for-bbf/
bigford632- Posts : 42
» Trick Flow A460 360cc heads cnc flow numbers
» Trick Flow street Flow numbers
» BBF flow numbers
» 466 Engine
» C 460 flow numbers
» BBF flow numbers
» 466 Engine
